skin is for openBH image version 5.0 - 5.1
skin with 15 different skins
Information about the skin :
Built from scratch on the image's default skin
- Some menus were designed and created with tires dedicated to this skin to give greater aesthetics and exploitation of spaces
- The first skin is the official basic virtual skin and is designed in a simple way without additions of posters....
- 15 sides of the skin are designed to accommodate the largest possible segment with the tastes of users on different scripts on one housing to give lightness and avoid annoying heaviness.
- Skins from 1 to 14 contain showing posters, backdrops and banners, depending on the addition of XetraEvent
The multiplicity of shapes and posters from one side to the other was taken into account, according to the user and his taste
The differences between the facets of the skins in several places, the most important of which are
- The first bar - The second bar - Channel list
- Poster frames have been added to give the image an aesthetic within the frame that appears directly with the poster in most aspects
- Add rating and movie information from rating and age groups, and each category has a custom color on the interface of the channel list and the first info bar
Supporting the infobar with everything that is auxiliary to the type of channel system, open or paid, “encrypted” with a color dedicated to encryption and some aspects, even the hosting of the Shring subscription, the type of connection, wired or wireless, the weather and the name of the region
- Add a mini screen for the channel in the channel list
Skin for openBH image BO-HLALA ☆ SKIN ☆ Xevnt.FHD
- Has thanked: 14333 times
- Been thanked: 1640 times
