Enigma2 Plugins FuryBiss
Has thanked: 14325 times
Been thanked: 1629 times
⚡ New FuryBiss 7.1 Update
🔥 Exclusive designs with various additions
◀️ Update Features
1️⃣ Ability to change the plugin theme
via Feeds layout
2️⃣ Ability to manually enter codes
◀️ Simply search for the channel, hover over it, and press and hold the 0 button
3️⃣ Automatic detection of the emulator path
💥 However, the emulator must be activated from the image
💥 The plugin does not recognize installed emulators
💥 It is recommended to use Oscam
4️⃣ Support for aarch64 processor on the OpenPLY 3.9 image
5️⃣ Updated screen display of current channel information by pressing the info button while opening the settings screen
🔥 The path to save the codes must be chosen as shown in the images 🔥
✋ Note: Feeds appear in the plugin when It's available, and a pop-up notification will appear.
Talent Command 🔻
[code]wget -q "--no-check-certificate" https://raw.githubusercontent.com/islam-2412/FuryBiss/refs/heads/main/fury/installer.sh -O - | /bin/sh
[/code]
Installation Script Link 🔻
FuryBissPro-Installer.sh
💥 Updates are available from within the plugin.
