APPLE IPHONE 18 PRO MAX - USER OPINIONS AND REVIEWS
Has thanked: 14333 times
Been thanked: 1641 times
NETWORK Technology
GSM / HSPA / LTE / 5G
LAUNCH Announced Not announced yet
Status Rumored
BODY Dimensions -
Weight -
Build Glass front (Ceramic Shield 2), aluminum frame, aluminum back/ glass back (Ceramic Shield)
SIM · Nano-SIM + eSIM + eSIM (max 2 at a time; International)
· eSIM + eSIM (8 or more, max 2 at a time; USA)
· Nano-SIM + Nano-SIM (China)
IP68 dust tight and water resistant (immersible up to 6m for 30 min)
Apple Pay (Visa, MasterCard, AMEX certified)
DISPLAY Type LTPO Super Retina XDR OLED, 120Hz, HDR10, Dolby Vision
Size 6.9 inches, 115.6 cm2 (~90.7% screen-to-body ratio)
Resolution 1320 x 2868 pixels, 19.5:9 ratio (~460 ppi density)
Protection Ceramic Shield 2
Anti-reflective coating
PLATFORM OS iOS 27
Chipset Apple A20 Pro (2 nm)
CPU Hexa-core (2x GHz + 4x GHz)
GPU Apple GPU (8-core graphics)
MEMORY Card slot No
Internal 256GB 12GB RAM, 512GB 12GB RAM, 1TB 12GB RAM, 2TB 12GB RAM
NVMe
MAIN CAMERA Triple 48 MP, f/1.6-4.0, 24mm (wide), 1/1.28", 1.22µm, dual pixel PDAF, sensor-shift OIS
48 MP, f/2.8, 100mm (periscope telephoto), 1/2.55", 0.7µm, PDAF, 3D sensor‑shift OIS, 4x optical zoom
48 MP, f/2.2, 13mm, 120˚ (ultrawide), 1/2.55", 0.7µm, PDAF
TOF 3D LiDAR scanner (depth)
Features Dual-LED dual-tone flash, HDR (photo/panorama)
Video 4K@24/25/30/60/100/120fps, 1080p@25/30/60/120/240fps, 10-bit HDR, Dolby Vision HDR (up to 120fps), ProRes, ProRes RAW (up to 120fps), Apple Log 2, 3D (spatial) video/audio, stereo sound rec.
SELFIE CAMERA Single 18 MP multi-aspect, f/1.9, 20mm (ultrawide), PDAF
SL 3D, (depth/biometrics sensor)
Features HDR, Dolby Vision HDR, 3D (spatial) audio, stereo sound rec., ProRes RAW, Apple Log 2
Video 4K@24/25/30/60fps, 1080p@25/30/60/120fps, gyro-EIS
SOUND Loudspeaker Yes, with stereo speakers
3.5mm jack No
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac/6e/7, tri-band, hotspot
Bluetooth 6.0, A2DP, LE
Positioning GPS (L1+L5), GLONASS, GALILEO, BDS, QZSS, NavIC
NFC Yes
Radio No
USB USB Type-C 3.2 Gen 2, DisplayPort
FEATURES Sensors Face ID, accelerometer, gyro, proximity, compass, barometer
Ultra Wideband (UWB) support (gen2 chip)
Emergency SOS, Messages and Find My via satellite
BATTERY Type 5100 mAh
Charging Wired, PD3.2, AVS, 50% in 20 min
25W wireless MagSafe/Qi2, 50% in 30 min (15W - China)
4.5W reverse wired
MISC Colors Coffee Brown, Purple, Burgundy
