XDreamy_FHD_Mod
XDreamy_FHD_Mod
XDREAMY v 5.3.0
"Experience Enigma2 skin like never before with XDREAMY"
Update the Installation Script to check, download, and install the required dependencies during the installation. (Experimental)
Update the installation script to use the distro-logo located in unknown images to use it as an image logo. (Experimental)
Update the iConverlibr.py and posters rendering using ChatGPT.
Add a Transparent color scheme to replace Skin Style 6, which was previously removed.
Add screen for the new Device Manager.
Add a Black color Scheme (New).
Add one style channels list full (Grid09).
Clean, Optimize, and uniform skin code for better response.
Add more items to XDREAMY TOOLS BOX (SmartAddnsPanel, ElisatPanel, MagicPanel, IPAudiopro, OAweather...etc)
Fixes and Improvements.
Telnet Code
(Direct Install)
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Inspr ... staller.sh -O - | /bin/sh
enigma2-plugin-skins-xDreamy_5.3.0_all.ipk/file
https://www.mediafire.com/file/zbtufafm ... l.ipk/file
Telnet Code
(Direct Install)
Re: XDreamy_FHD_Mod
XDREAMY v 5.4.0
A new level of poster download and display continues the improvements in rendering and methodology, which are now more accurate, faster, and perfect.
Add a new option in the infobar to swap between crypto-name and crypto-bar to change the look of channel encryption.
Improvement in skin response speed as after speed poster improvements.
XDREAMY PLUGIN: Code optimization.
Telnet Code:
enigma2-plugin-skins-xDreamy_5.4.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=7754
Telnet Code:
Re: XDreamy_FHD_Mod
XDREAMY v 5.6.0
What’s New in XDREAMY v5.6.0
Installation Script Enhancements
I’ve made significant improvements to the installation and removal scripts to ensure a smoother and more user-friendly experience. The updated scripts are now more accurate and informative, providing clear feedback during the installation process. This makes it easier for users to track and understand what’s happening on their device.
Restore back the option to detect the box model and add boximage to skin folder automatically
XDREAMY Plugin Updates
The XDREAMY plugin has been upgraded with exciting new customization options, allowing you to personalize your skin like never before. Here’s what’s new:
1- Customizable Skin Colors
You can now personalize the skin’s appearance by adjusting four key color variables:
Titles Font Color: Choose the color for title text to improve readability.
Text Font Color: Select the primary text color for better clarity.
Selection Color: Customize the highlight color for selected items.
Background Color: Set the background color to match your preferences.
To use this feature, simply select the "Custom" option in the Skin Color settings. A list of color variables will appear, allowing you to make changes in any order and as often as you like. Create a skin that truly reflects your style and enhances your viewing experience!
2- Font Style and Size Customization
Personalize your skin further by adjusting the font style and size directly from the XDREAMY plugin—no need to upload additional files.
Font Style: Choose your preferred font style directly from the plugin. The new option automatically writes the selected font name to the font file.
Font Size: Adjust the font size with ease. Increase or decrease the size in 5% increments, with a range of up to 35% larger or smaller, depending on your preferences and the font type you choose.
3- Show in the Extension Menu
We’ve added an option to include the XDREAMY Plugin in the extension menu for quick and easy access. This makes it more convenient to customize your skin on the go.
XDREAMY Tools Box Improvements:
The Tools Box has been upgraded with new features to enhance usability:
Plugin Picture Preview: The updated Tools Box now includes a plugin picture preview feature, making plugins more visible and easier to identify.
This version is more polished, professional, and easier to read while maintaining the original intent of your post. Let me know if you’d like further adjustments!
Code: wget -q "--no-check-certificate" https://raw.githubusercontent.com/Inspr ... staller.sh -O - | /bin/sh
enigma2-plugin-skins-xDreamy_5.6.0_all.ipk/file
https://www.mediafire.com/file/wv46u12d ... l.ipk/file
Re: XDreamy_FHD_Mod
XDREAMY v 5.7.0
"Experience Enigma2 skin like never be("01-01-2025"),
("01-01-25"),
("2025-01-01"),
("25-01-01"),
("01/01/2025"),
("01/01/25"),
("01/01/2025"),
("01/01/25"),
("2025.01.01"),
("25.01.01"),
("Monday, 01 January 2025"),
("Mon, 01 Jan 2025"),
("Monday 01 January 2025"),
("Mon 01 Jan 2025"),
("01 January, 2025"),
("01 Jan, 2025"),
("January 01, 2025"),
("Jan 01, 2025"),
("2025 January 01"),
("2025 Jan 01"),
("25 January 01"),
("25 Jan 01"),
("01.01.2025"),
("01.01.25"),
("01 01 2025"),
("01 01 25")]
To use this feature, select the date format from the Date Format option in the Skin plugin settings. A list of date variables will appear. Create a skin that truly reflects your style and enhances your viewing experience!
2- Posters Improvement
More improvement in poster rendering, through updating the regex and improving it, now you have better, more effective, and more accurate posters than ever before,
XDREAMY General Improvements:
1. More improvement in skin file structure, merge more files to reduce the files count.
2. More reduction in skin overall size (the ipk size now is 16.2 MB) which mean better performance on low-memory devices with more features.
3. Handel some user's requests and minor fixes.
Code:
"All updates to the skin and its plugin, starting from version 5.2, are based on artificial intelligence generators and are not derived from previous works of any developer. If any similarity is found between the code used and specific works, it is most likely that the developer is using the same approach in writing their code."
enigma2-plugin-skins-xDreamy_5.7.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=8218
("01-01-25"),
("2025-01-01"),
("25-01-01"),
("01/01/2025"),
("01/01/25"),
("01/01/2025"),
("01/01/25"),
("2025.01.01"),
("25.01.01"),
("01 Jan, 2025"),
("Jan 01, 2025"),
("2025 Jan 01"),
("25 January 01"),
("25 Jan 01"),
("01.01.2025"),
("01.01.25"),
("01 01 2025"),
("01 01 25")]
Code:
Re: XDreamy_FHD_Mod
XDREAMY v 5.8.0
What’s New in XDREAMY v5.8.0
Last Version (Ramadan Break)
1. Skin Files Structure Improvements
The merging and optimization of skin files are already a huge step forward. To make it even more efficient and user-friendly,
2. Posters Rendering System
The new rendering technique sounds amazing! Let’s make it even more efficient and delightful.
Code:
enigma2-plugin-skins-xDreamy_5.8.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=8283
Code:
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
Re: XDreamy_FHD_Mod
-Update 06.03.2025-
XDREAMY v5.8.1
What’s New in XDREAMY v5.8.1 (Online Update only)
1. Fix E2IPlayer screen
2. Fix HistroyZapSelector Screen changes
Thx @ Mahmoud
XDREAMY v5.8.1
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Insprion80/Skins/main/xDreamy/installer.sh -O - | /bin/shThx @ Mahmoud
Re: XDreamy_FHD_Mod
XDREAMY SKIN V 6.0 (Update plan)
1. Add 10 more new color sets (Done)
2. Add an option to enable/disable Posters rendering from XDREAMY plugin (Done).
3. Add an option to change the poster auto-remove interval from XDREAMY plugin (Done).
4. Add an option to change poster location from the XDREAMY plugin (Done but manually, still needs some work).
5. Remove the check skin function as it is useless for users and no one uses it even me.
6. Add Blind scan screens & Radio screens...etc.
7. Hnadel some other requests.
Some Screen Shoots for the new colors. I hope you like it.
Re: XDreamy_FHD_Mod
XDREAMY v 5.9.0
What’s New in XDREAMY v5.9.0
The last update to the XDREAMY skin is packed with new features, improvements, and customization options to enhance your Enigma2 experience. Here’s what’s new:
New Features & Enhancements
Fresh Skin Styles
Added 3 new skin styles to give XDREAMY a modern and refreshed look. Explore these styles and find the one that suits your taste!
10 New Color Templates (Egypt Templates)و Introducing 10 vibrant and fresh color templates inspired by the beauty of Egypt. These templates bring a lovely and unique touch to your display.
Transparency ControlA brand-new Transparency Control option for the skin background! Adjust the transparency level to create a fancy and personalized look. This feature works with both color templates and custom colors.
Customizable Clock Layout
Added an option to switch between 12-hour and 24-hour clock formats. This is just the beginning of more customization options for clock layouts in future updates.
Poster Rendering Control
For the first time, you can now enable or disable poster rendering directly from the XDREAMY plugin. Take control of your display and optimize performance.
Poster Auto-Remove Interval
A new option to adjust the poster auto-remove interval from the XDREAMY plugin. This gives users more control over memory usage and system performance.
Improved Plugin Status Detection
Enhanced the XDREAMY TOOLS BOX plugin status detection for a better user experience. Now, it’s easier to know if the plugin is installed on your system.
Removed Unnecessary Features
The check skin function has been removed as it was unused and unnecessary.
New Screens & Layouts
Added Blind Scan screens, Radio screens, and more preview screens to improve functionality and visual appeal.
Handling User Requests
We’ve listened to your feedback! This update includes fixes and improvements based on user requests.
XDREAMY Value Your Feedback!
Your suggestions drive our updates. Let us know what you think of the new features and what you’d like to see in future versions.
Download & Installation
Ready to upgrade? Download the latest version of XDREAMY now and follow the installation instructions.
Direct Telent Install
Download IPK (Mediafire)
enigma2-plugin-skins-xDreamy_5.9.0_all.ipk
Fresh Skin Styles
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Insprion80/Skins/main/xDreamy/installer.sh -O - | /bin/shDownload IPK (Mediafire)
https://www.mediafire.com/file/0lkrovy9novj2zy/enigma2-plugin-skins-xDreamy_5.9.0_all.ipk/fileenigma2-plugin-skins-xDreamy_5.9.0_all.ipk
https://www.satworld-forum.com/download/file.php?id=8717 - Hannibal_Lecter
Re: XDreamy_FHD_Mod
XDREAMY v 5.9.1
What’s New in XDREAMY v5.9.1:
The last update to the XDREAMY skin is improvements, and customization options to enhance your Enigma2 experience.
Also many fixes and improvements based on your valuables comments and feedback.
enigma2-plugin-skins-xDreamy_5.9.1_all.ipk
https://www.satworld-forum.com/download/file.php?id=9128- Hannibal_Lecter
Re: XDreamy_FHD_Mod
XDREAMY v 5.9.2
What’s New in XDREAMY v5.9.2
Add Plugin Translation (Experimental)
Arabic
Chinese thanks icanbefly, who helped push forward to achieve this.
Serbi and Corati, thanks milan58
enigma2-plugin-skins-xDreamy_5.9.2_all.ipk
Arabic
https://www.satworld-forum.com/download/file.php?id=9276Who is online
