IPTV Extreme v116.0 [Firestick/AndroidTV/Mobile] [Official] [Licensed]
Been thanked: 1027 times
Overview: Watch IPTV from your service provider or free playlists found across the Web
*** PLEASE NOTE THIS APP DOES NOT CONTAIN ANY CHANNLES ***
*** THE APPLICATION REQUIRES A PLAYLIST TO WORK ***
Please don't ask me for playlists, I don't have / don't share / don't sell playlists!
For the Playlist you can search for some IPTV Forum
If you usually use VLC or IPTV bouquet for Dreambox to watch TV this app is for you.
You need to use your own IPTV list to watch channels
I suggest to install VLC for Android or Better MX Player if the default Video Player is not able to Play streaming video
If you would like to translate the applcation in your language please contact me!
Features:
- Integrated Player (Advanced & Light)
- Chromecast Support (Beta)
- Parental Control
- Remote Controller support
- Backup / Restore Settings
- M3U playlists support
- Multi EPG support (TV Guide)
- Auto EPG update
- EPG alias management
- All the EPG providers are included
- Picons support in different size
- Ability to download On Demand Programs!
- Ability to record Live Streaming with time limit!
- More than 10 Themes availables!
- Time Recording
- Timers Management
- Autostart On Boot Function
- Set Memo function for Events on TV Guide
- Search for Similar Events on TV Guide
- Sliding EPG time
Additional features are available in Pro version:
- Ad free
- A big thanks from me
Setup instructions:
* First you'll need to add a Playlist by inserting m3u link or select a previously saved playlist file.
VERSION 116.0
-Backup now supports VPN Profiles
-Improved MAG support
-Improved Groups management
-Improved performance
-Improved Edit playlist options
-Players libraries Updated
-Fixed minor issues on Android 11 and above
-Bug Fix
Tested With Clean Install On A11Box, OnnBox, Gen2FS, Gen3FS, SmartFireTV, SmartAndroidTV, 3 Older Boxes, 6,7,8,9 & 10 Phones
No Mouse Toggle Needed
App Is Fully Functional With Option In Settings To Choose Banner Ads Instead Of Full Screen Ads(Minimal)
Tested For 3 Hrs Straight On A Device & Never Got Any Ads
This app has advanced overlay or banner advertisements
http://ul.to/71xxxa75
