frequencies of the Poland Plus channel package on Hotbird satellite will change FEC.
A comparison between the weak frequency of 10719 and the frequency of 11488 in the Hotbird satellite, both of which were recorded at the same time, clearly shows that the quality of the signal in the frequency of 11488 has increased significantly compared to one of the weakest frequencies of the Hotbird satellite. However some users are getting 10719 which is weak but missing 11488!
It seems that the new changes have caused an increase in the signal for some points and a decrease or interruption of the signal in some points.
Make your comment here
Current status of frequencies 11488 and 11278 on Hotbird satellite with new FEC 5/6
Some report signal enhancement and some report complete signal cutoff in Asia
In our area , the signal amplification is quite noticeable.
Signal amplification of another Hotbird frequency
The FEC value of frequency 11488 belonging to Poland's Channel Plus package on Hotbird satellite was changed from 3/4 to 5/6. At the same time, the quality of the signal has also been increased . The signal level of this frequency in parts of the Middle East is almost the same as the old Hotbird 13C satellite, which was previously received without problems in asia
If you have had trouble receiving this frequency before, please check the following specifications now:
Hotbird 13.0°E
DVB-S2 | 11488 H 27500 5/6
- Has thanked: 14325 times
- Been thanked: 1631 times
- 22 Views
- 5 Replies
- 1093 Views
- 6745 Views
- 1359 Views
- 2473 Views
Last post by robertsdudlett
