[Plugin] SamsungTVPlus
ocean777
E2 Developer
E2 Developer
Has thanked: 240 times
Been thanked: 210 times
Andorra
Post by ocean777 »
Update 18042024
- Added support for ignore/replace lists:
- the lists must be copied to ./data from the plugin:
- an example list of samsungtvplus.ignore is also installed:
- the lists can easily be derived from existing .m3u8 playlists:
- in the ignore list (.ignore) only the stream URLs need to be deleted or:
- be changed in the replace list (.replace).
thanks Billy2011
enigma2-plugin-extensions-samsungtvplus_20240418_all.rar
(170.3 KiB) Downloaded 64 times
