v8.5.0 .. 2023-02-04
- Added "Plugins Browser" to the Plugins page (with plugin icons and group selection).
.. This will replace the functionality of "Plugins Additional Menus" , "Startup Plugins" , "Extensions and System Plugins".
- Added "Upgradable Packages" to the Plugins page (to upgrade packages).
.. It is recommended that you use the option "Update Packages List from Feed" to get the latest list.
Added the option "Change Custom Commands File" to Terminal Custom Commands Options (Yellow Button).
.. You can load any file that start with "ajpanel_cmd" or "LinuxCommands" (case insensitive).
.. File name examples:
... ajpanel_cmd
... ajpanel_cmd_20012023.txt
... ajpanel_cmd_myPlugins_commands_2023_01_20
... LinuxCommands
... LinuxCommands.txt
... linuxcommands_install_20_plugins.myFile
- Improved "Restore Tuner Settings" for VTi to be able to restore from backups from other images.
.. This feature is already available for other STBs and images.
- Improved File Manager:
.. Added progress bar during the process of copying/moving files and directories.
.. Added functionality to process M3U8 files "M3U/M3U8 File Browser".
.. Added functionality to extract ".gz" single compressed file.
- Added new Setting "Subtitle Files Encoding Priority" to set the first encoding to use with .srt files.
- Improved changing Subtitle Delay (with Left/Right arrows) to show current delay in a popup message.
- Improved the Player-Bar to show the current running player.
- Improved "M3U/M3U8 File Browser" grouping and filtering + handling of different M3U/M3U8 formats.
- Improved Terminal "Info" button in Custom Commands table to show more command info.
- Fixed incorrect text viewer height on VTi.
- Fixed FTP file-upload to stop properly when the user cancels the upload.
AJPanel latest Version
- sugar
- Has thanked: 73 times
- Been thanked: 1672 times
Re: AJPanel latest Version
- enigma2-plugin-extensions-ajpanel_v8.5.0_all.deb
- (269.1 KiB) Downloaded 24 times
- enigma2-plugin-extensions-ajpanel_v8.5.0_all.ipk
- (329.87 KiB) Downloaded 28 times
- Has thanked: 10124 times
- Been thanked: 1255 times
[v8.6.0 .. 2023-02-26]
- Added "Package Creator" in Plugins page to create ipk/deb/tar.gz packages from a custom project file.
.. This creates a project directory & project with everything you needed to create ipk/deb/tar.gz packages.
.. Once the project is created, start collecting the paths of the directories/files need in the include.
.. Adding a directoring to the project will automatically add all its contents when creating the package.
.. The control parameters for ipk/deb packages are initially added added from a template.
.. You can copy the control parameters from any installed packages.
.. You can import your custom control script files into the project directory (using the menu).
.. The menu will help you pick the Dependencies from a list. Removing a dependancy is also possible.
.. Pre and Post actions like Restart/Reboot can also be set.
.. Note: This can be utilized to create a .tar.gz backup for your selection of directories and files that are scattered in the system.
- Improved Portal Servers handling:
.. Improved Portal Servers EPG handling.
.. Improved playing Live channels on some portal servers which did not work before.
.. Added new settings option "Portal Servers Connection Timeout (seconds)" for custom connection timeout. Increasing the timeout to 4 seconds helped with some portal servers.
- Added new IPTV option "Change Bouquet References to Unique Codes .." to handle one bouquet at a time.
- You can add you blacklist of words you need to hide in IPTV tables.
.. This works along with the settings "Skip A*** Channels (from IPTV Server)" to hide words.
.. Example: Adding "acbd" will hide all IPTV Catogries/Channels that include "acbd" from IPTV tables.
.. How to set it:
... 1- Create the file "ajpanel_iptv_blacklist" in the panel's backup directory.
... 2- Start adding the words you need to hide (each word in a separate line and is case-insensitive).
- You can add your custom IPTV prefix words to remove from IPTV tables.
.. This works along with the settings option "Remove IPTV Channel Name Prefix (|EN| , |AR|Drama|)".
.. Example: Adding the word "Sport | En:" will remove it from all IPTV channel names in the tables.
.. How:
... 1- Create the file "ajpanel_iptv_prefix" in the panel's backup directory.
... 2- Start adding the prefixes you need to remove (each in a separate line and is case-insensitive).
- Improved the option "Active Feeds" to show the feed in a table with number of packages in each feed.
- Improved File Manager to refresh the file list after editing a file (to show the new ***.bak file).
- Fixed the problem of incomplete download of PIcons/EPG when updating for current bouquet.
- Fixed the crash that occurs after downloading PIcons from IPTV tables.
- Fixed the crash that occurs on Dream-Two-OE2.6 when opening subtitle font selection menu.
- Fixed a crash on OpenATV-7-2 when opening "Download Manager" (if ehe files in progress have been deleted).
- General improvements and bug fixes.
.. How to set it:
.. How:
"Join New Forum Satworld-forum.com"
- sugar
[v8.6.2 .. 2023-03-01]
- Improved Portal Channel-Info to update system EPG.
.. Note: Opening Info-Window while playing IPTV channels, the received EPG and PIcon will be imported into the system. This works for Portal/Playlist servers.
- Fixed portal zapping in bouquets to point to the right name in Channel List.
.. The problem was encountered with old bouquets that were added prior to v8.6.1.
- Improved portal tables to point to the current source of the playing channel (if the channel is from the same server).
.. This means that when you start browsing the portal server for the current playing channel, the tables will point to the source of the channel all the way to the last table.
.. This feature will work on bouquets that will be added from now on (starting with this version).
- Improved "Channels Browser" to handle PIcons with spaces removed from their file names.
- enigma2-plugin-extensions-ajpanel_v8.6.2_all.ipk
- (340.46 KiB) Downloaded 23 times
- enigma2-plugin-extensions-ajpanel_v8.6.2_all.deb
- (276.83 KiB) Downloaded 22 times
- sugar
v8.6.3 2023-03-01
- enigma2-plugin-extensions-ajpanel_v8.6.3_all.ipk
- (340.46 KiB) Downloaded 29 times
- enigma2-plugin-extensions-ajpanel_v8.6.3_all.deb
- (276.8 KiB) Downloaded 20 times
- sugar
v8.7.0 .. 2023-03-08]
- Added "Bouquet Editor" with Multi-Selection Delete/Move/Sort.
.. Can also rename bouquets/services and add/edit markers.
- Fixed a crash on Dream-Two (when saving settings).
- enigma2-plugin-extensions-ajpanel_v8.7.0_all.ipk
- (357.58 KiB) Downloaded 39 times
- enigma2-plugin-extensions-ajpanel_v8.7.0_all.deb
- (293.62 KiB) Downloaded 31 times
- 1037 Views
- 3 Replies
- 6886 Views
- 12890 Views
Last post by dreamworld
- 1418 Views
- 2405 Views
- 2551 Views
Last post by gateway3210
- 860 Views
- 458 Views
- 6 Replies
- 859 Views
Last post by kingsman
- 2821 Views
