AJPanel latest Version
Has thanked: 14325 times
Been thanked: 1629 times
AJPanel V5.3.0
- Added "Check & Filter" option to filter accessible portals.
- Improved the plugin to handle new portal versions.
- Improved "Info" EPG for Satellite services to show Genre and Parental Rating (if provided by service).
- Improved "Dev. Info." >> "Disk Usage" to show the File System Type.
- Improved IPTV channel name prefix cleaning.
- Renamed IPTV menu option "M3U/M3U8 Channels Browser" to "M3U/M3U8 File Browser".
- Fixed player bar (sometimes hangs when playing unstable Live portal channels).
- Fixed copying a directory to another one where same name exists (in File Manager).
- Improvements and bug fixes.
Thx @Biko-73
enigma2-plugin-extensions-ajpanel_v5.3.0_all.ipk.zip
(239.42 KiB) Downloaded 324 times
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1664 times
Been thanked: 405 times
Re: AJPanel V5.3.0
Post by admin »
v5.5.0 .. 2022-06-26
- Enabled Player Bar "Refresh" (Green Button) for all types of services.
.. Refreshing a movie/series should restore the last playing position (server dependent).
.. Note: The Menu option "Restart Current Service" resets the service without restoring the movie/series position.
- Added a simple Download Monitor to show brief download info on top left of the screen (even outside AJPanel).
.. It can be enabled/disabled from Download Manager options (Yellow Button).
- Improved the Settings option "IPTV Hosts Files Path (Playlist, Portal, M3U)" to have more than one custom directory.
.. This should fix the search slowness on devices with external media, multi-boot (with huge number of files).
.. You can edit your favourite search-paths list (for Playlist/Portal/Stalker/M3u/M3u8 files).
- Changed Hotkey access to AJPanel to always open the Player Bar.
This is for faster access to options like Subtitle/IPTV/Download Manager, etc.
.. The Signal Monitor can also be opened from the bar menu (or from within AJPanel).
- Improved Subtitle handling.
.. Fixed system subtitle not showing after refreshing a service.
.. Added Subtitle background (black with transparency level selection).
.. Added menu to subtitle settings to reset the delay to 0 (faster reset if delay is far from 0).
.. Increased maximum Subtitle Font Size (from 80 to 100)
.. Increased maximum Subtitle Delay seconds (from 60 to 300)
- Added a menu to Text Viewing Window with option to Enable/Disable Wrapping, Align (Left/Right/Center) and Save to File.
- Improved filtering of IPTV channel name prefixes to include more patterns.
Improved reading server data form Playlist/Portal files with non-ASCII characters.
- Fixed AJPanel update from Settings (for Debian system).
- Fixed the crash that occurs when "lamedb" file is not in "UTF-8" Encoding.
- Fixed the crash that occurs when trying to find a service from Channel Context Menu.
enigma2-plugin-extensions-ajpanel_v5.5.0_all.ipk.zip
(244.52 KiB) Downloaded 203 times
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Re: AJPanel latest Version
Post by sugar »
v7.2.0 .. 2022-10-06
- Added options in Main Page menu to change the fonts for the System/AJPanel/Terminal.
.. This offer the fonts from "/usr/share/fonts/" where you can add otf/ttf fonts.
.. Changing the fonts take place immediately (no restarts required).
.. The only case you need a restart is when you want to return the system fonts to their defaults.
- Added IPTV Browser (with PIcons/Posters).
Added IPTV option to add favourite Playlist/Portal server to IPTV menu (for easy access).
- Added separate options to open the Player Bar and Signal Monitor (as alternative access for images with no Hotkeys).
.. The options are available in "Services/Channels" page and system "Extensions menu".
- Improved Subtitle:
.. The option "Suggest srt files" is now faster and with better sensitivity.
.. Add functionality to remove Arabic Diacritics (Tashkeel) to prevent gaps between the letters.
.. Added RCU keys to control a playing movie (Pause, Play, Audio, SUBT, Forward, Rewind).
.. Added Left/Right keys to synchronize the subtitle (to jump back and forth in lines).
.. Added "OK" Button to subtitle settings to show a menu with values for each setting item.
.. Improved Subtitle Line Picker (Blue Button) to highlight the current line.
.. Improved Font selector to offer the fonts from "/usr/share/fonts/" where you can add otf/ttf fonts (no restarts required).
.. Fixed Subtitle layout for HD-Skins.
- Improved PIcons Manager to be able to change PIcons background transparency color.
- Added options to File Manager to view MVI files + Convert jpg/png to mvi (for bootlogo).
- Improved Tables: Added "Edit Filter" (Yellow Button) to Find-in-Table to be able to edit the filter file in all tables.
- Improved IPTV prefix removal (for more new cases).
- Fixed the issues with toggling the Readers State (ON/OFF) for the original and patched OSCam variants.
- Fixed a crash during Channels Backup (caused by Unicode characters in the names of bouquets files).
The Player Bar and Signal Monitor can be opened individually with different methods.
From within the Panel.
Playing a channel from IPTV tables will automatically open the Player Bar and.
Playing a channel from DVB tables will automatically open the Signal Monitor.
From "Services/Channels" page, with the options:
"Open Player Bar"
"Open Signal Monitor"
From outside the Panel.
The Hotkey for the panel will open the Player Bar regardless of the playing channel.
You can use the system Extensions Menu (normally Blue Button) to open the Player Bar or Signal Monitor.
If the image on your device supports Hotkey-Setting, use it to link keys of your choice to access some options from the panel:
Note: You can open the Signal Monitor from the Player Bar with the Red Button.
- Menu >> Setup >> System >> Expert Settings >> Hotkey
- Select the key you want.
- Select "Plugins".
- Select any of the panel's options:
AJ File Manager
AJ IPTV Menu
AJ Player Bar
AJ Signal Monitor
enigma2-plugin-extensions-ajpanel_v7.2.0_all_deb.zip
(232.29 KiB) Downloaded 168 times
enigma2-plugin-extensions-ajpanel_v7.2.0_all_ipk.zip
(285.47 KiB) Downloaded 164 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v7.3.0 .. 2022-10-11
- Fixed IPTV Poster/PIcons Browser (not showing the images on Pure2-6.5/OpenATV-6.4 which have problems with jpg files).
- Fixed a crash caused by browsing M3U8 file from File Manager (with the option "Browse IPTV Channels").
- Improved adding favourite server to IPTV Menu to apply the change without exiting to main page.
- Imporved IPTV prefix removal for more new cases.
- Minor changes/fixes/imporvements.
enigma2-plugin-extensions-ajpanel_v7.3.0_all_ipk.zip
(285.77 KiB) Downloaded 148 times
enigma2-plugin-extensions-ajpanel_v7.3.0_all_deb.zip
(232.56 KiB) Downloaded 147 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v7.4.0 .. 2022-10-21
- Added Font Preview to font selector.
Added screenshot:
.. All screen contents can be captured with the keys : F1 , Long-Tv , Long-Tv/Radio
.. Video contents can be captured with the keys : F2 , Long-Radio , Long-0
.. OSD contents can be captured with the keys : F3 , Long-Help : Screenshot of video part
E - Screen shoot hotkey.jpg (19.9 KiB) Viewed 3062 times
.. The screenshot service can be switched off from settings
.. The image type can also be changed to jpg/png/bmp
.. The result files will be saved in your Export-Path
- Improved File Manager Picture Viewer to browse the picutre files in the same directory with Left/Right and Up/Down keys
- Name of screens on skin & date - time and all pass will create on screenshot name
شرح مكونات مسار الصورة.jpg (18.2 KiB) Viewed 3062 times
- Improved "Sat. List" (Yellow Button) in the option "Restore Tuner Settings" (to show the satellites in separate lines)
- Fixed empty screens (or incorrect text viewer height) on VTi and some DreamOS images
- Fixed a crash caused when clicking "Info" after searching in IPTV >> Series with "Find in Series"
- Fixed some issues with the panel update/resinstall for DreamOS
enigma2-plugin-extensions-ajpanel_v7.4.0_all_ipk.zip
(287.84 KiB) Downloaded 140 times
enigma2-plugin-extensions-ajpanel_v7.4.0_all_deb.zip
(234.58 KiB) Downloaded 137 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v8.0.0 .. 2022-12-01
- Added "Movies Browser" to main page. It read the movies from the directory set in the Settings (+ all its sub-directories).
Movies Browser+.png (1.15 MiB) Viewed 3056 times
- Added "EPG" option to main page. The option is also available in Channel List Context Menu >> AJPanel - Channels Tools.
- Added EPG Translation (experimental).
This feature works fine on OpenPLi-8.3.
However, some images may reset the EPG after restarts.
- Added feature to AJPanel Channel Info to translate the EPG part (based on the EPG Translation Language settings).
- Added multi-select feature to Terminal to run multiple commands.
Reactions Received
2,414
Points
6,533
Trophies
1
Posts
794
Nov 30th 2022
#65
- Added the option "Replay with" to Player Bar to replay the media with a different media-player.
- File Manager.
.. Added the option "Set as PIcon for current channel" to convert a picture file to PIcon.
.. Added the option "Play with" to select the player of the selected media file.
.. Added capability to play recorded IPTV stream (file extension ".stream").
.. Added Encoding Review (when viewing or changing file encoding).
.. Added menu options shortcuts to some common options.
.. Improved Picture Viewer to move the cursor to the last viewed file.
.. Added "Info" Button to Picture Viewer to show file properties.
- IPTV:
.. Improved access to old versions of Portal Servers.
.. Added option to IPTV options to save to bouquet name with provider name.
.. Added new filter to Local IPTV table (to filter Stream-Relay channels).
.. Improved IPTV main server page to show the current host by clicking the "Info" Button.
.. Improved M3U/M3U8 Browser for more m3u8 file formats.
.. Fixed "M3U/M3U8 File Browser" zap showing incorrect channel name in Player-Bar.
- Main Page:
.. Moved the option "Check Internet Connection" to Main page menu.
.. Added "AJPanel Requirements" option to Main page menu to check/install the packages required by some features in AJPanel.
.. Added "Help" option to Main page menu to list the shortcuts keys used in the page.
.. Added shortcuts to access all options in Main page with digis 1-9 and "<" ">". See details in Menu >> Keys Help.
- Added the option "Delete File" (Yellow Button) to "Bouquets Importer".
- Added a feature to all menus/options to jump to the row with a letter typed by RCU.
- Improved settings to use OK Button to show a menu with the available options (for easy selection).
- Improved AJPanel Settings Import ("Restore AJPanel Settings").
- Added ScrollBar to PIcons and Posters Browsers.
- Improved PIcons and Posters Browsers to hide the empty boxes.
- Fixed AJPanel installation GUI Restart command for Egami (in "postinst").
- Fixed Restore-Tuner for VTi (freezing after GUI Restart).
3 way to install panel
- install via telnet
Code
wget https://raw.githubusercontent.com/biko- ... staller.sh -O - | /bin/sh
- Upgrade from inside plugin after move "ajpanel_update_url" to yor backup folder
- Manually from ipk/deb
enigma2-plugin-extensions-ajpanel_v8.0.0_all-ipk.zip
(304.55 KiB) Downloaded 139 times
enigma2-plugin-extensions-ajpanel_v8.0.0_all-deb.zip
(248.13 KiB) Downloaded 143 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v8.1.0 .. 2022-12-03
- Added options to Movies Browser to change the poster for a movies.
- Fixed crashes on DM900 and Dream-Two:
.. When trying to access AJPanel Settings.
.. When applying the changes in the option "Copy EPG between Channels (from xml file)".
- Improved AJPanel internal update.
enigma2-plugin-extensions-ajpanel_v8.1.0_all_ipk.zip
(304.88 KiB) Downloaded 146 times
enigma2-plugin-extensions-ajpanel_v8.1.0_all_deb.zip
(248.36 KiB) Downloaded 143 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v8.2.0 .. 2022-12-16
- File Manager:
.. Added Multi-Select to Archive/Copy/Move/Delete user selected files and directories.
.. Improved file deletion to force delete some undeletable files.
.. Fixed shortcuts (showing search-by-typing instead of selecting the options).
.. Fixed properties (for empty directories).
- Improved portal handling for more portal servers (including very servers versions).
- Added option to Server Browser (Poster Mode) to use the selected poster for a Local Media file.
- Added "0" key to Movies/Poster/PIcons Browsers to jump to first/last item in the listed items.
- Added "Help (Keys)" menu option to Movies/Poster Browsers.
- Added menu to IPTV Page to delete Favourite Server Menu Option.
- Improved tables to show green column title (if sorted in ascending order) and blue (if descending order).
- Fixed Tables not sorting the same column in ascending after sorting it in descending order.
enigma2-plugin-extensions-ajpanel_v8.2.0_all_ipk.zip
(308.75 KiB) Downloaded 140 times
enigma2-plugin-extensions-ajpanel_v8.2.0_all_deb.zip
(251.22 KiB) Downloaded 130 times
sugar
Global Moderator
Global Moderator
Post by sugar »
[v8.3.0 .. 2023-01-01]
- Added Network option to Main Page to handle network functions.
.. Added Network and Port Scanner options.
.. Moved the option "Check Internet Connection" to the new Network option.
- Added FTP File Browser (remote File Manager on network devices) with the following features:
.. Transfer files between local and remote storage.
.. Play remote movies (if streaming is active on remote devices).
.. View remote picture files.
.. Create directories and Rename/Delete files/directories on remote device.
.. Tested on network attached devices such as NAS, Receivers, Laptops/PCs and Router USBs.
- Improved portal handling to access more portal servers versions.
enigma2-plugin-extensions-ajpanel_v8.3.0_all.ipk
(315.62 KiB) Downloaded 139 times
enigma2-plugin-extensions-ajpanel_v8.3.0_all.deb
(256.8 KiB) Downloaded 136 times
sugar
Global Moderator
Global Moderator
Post by sugar »
v8.4.0 .. 2023-01-09
- Added "Channels Browser" option to the System "Channel Context Menu" to browse channels with PIcons
.. From System "Channel selection", click menu then "AJPanel - Channels Browser".
.. It works on all types of groups (All, Satellites, Provider, Favourites) including IPTV bouquets.
- Added menu option "Add FTP Media to Bouquet" to Player menu (to add the streamed media from FTP to local bouquets)
- Improved Portal channels zap
- Fixed FTP Exit (cannot exit if "File Manager Exit-Button Action" setting is set to "Directory Up")
- Fixed the crash reported on systems with low resources when scanning the network.
enigma2-plugin-extensions-ajpanel_v8.4.0_all_ipk.zip
(317.63 KiB) Downloaded 158 times
enigma2-plugin-extensions-ajpanel_v8.4.0_all_deb.zip
(258.67 KiB) Downloaded 151 times
