Octagon sf 8008 not work
- coderharry
- New Member
octagon sf 8008 not working after image update is there any way to get it back it will not take a network update and there is no image in it now
- Has thanked: 14331 times
- Been thanked: 1640 times
Re: Octagon sf 8008 not work
Use serial cable and update with original firmware
- coderharry
- New Member
could you give me a link to the original firmware if you could and some instructions on how to get it going would be needed to
To get to the recovery menu, use the following procedure:
1. Switch off the box
2. Press and hold any button on the remote control
3. Switch on the box at the power switch
4. After 6-7 seconds, release the button on the remote control
5. then you will enter recovery mode
6. then upgrade to Network Multiboot ok, select image and start upgrade
7. When finished, start Exit and Multiboot Selector Image with OK
