Tiger t3000 forever powervu not working
skywatcher
Been thanked: 1 time
United States of America
Post by skywatcher »
Hi I just got a tiger t3000 works great on fta and biss but when you try powervu channels the picture and sound stops and starts then locks up the only thing I can't set is NTSC for north america it has it but its only 750p/50 any thing else goes to PAL settings so I can set the resolution . I think it's a software problem when powervu trys to play #in Mbps when it stops it's 0.0 Mbps quality is 99% does anyone have an answer. Thanks
Has thanked: 14324 times
Been thanked: 1623 times
Re: Tiger t3000 forever powervu not working
It’s software problem mate you can downgrade
Regarding
skywatcher
Hi again does anyone know what software worked in North America or how to let Tiger know there a problem. Thanks
skywatcher wrote: ↑30 Jul 2023, 23:54 Hi again does anyone know what software worked in North America or how to let Tiger know there a problem. Thanks
Hi mate use this software
https://www.mediafire.com/file/34uppo1w ... 2.bin/file
skywatcher
Hi tried the software still can't set NTSC all we goes back to PAL so powervu starts and stops. THANKS for trying . any one know how to contact Tiger
skywatcher wrote: ↑01 Aug 2023, 06:01 Hi tried the software still can't set NTSC all we goes back to PAL so powervu starts and stops. THANKS for trying . any one know how to contact Tiger
But there Automatically adjust NTSC & PAl
Return to “Others STB”
