Latest image version (5.2.003) from here:
Obh
online update also available.
OpenBh Image for EDISION OS-mio 4K+
- Has thanked: 14325 times
- Been thanked: 1629 times
Re: OpenBh Image for EDISION OS-mio 4K+
New file "openbh-5.3.004.release-osmio4kplus-446c978b", from here:
Obh
Obh
- Zaam
- Has thanked: 375 times
- Been thanked: 220 times
New update:
5.3.0.16
Set the resolution of your tv (2160p, 1080p etc) then select Refesh Rate auto (not all boxes support p24, so those boxes will not be affected).
For 99% of users with a modern tv set, you should only need to use the Refresh Rate auto option and HDMI Colourspace should be set to Auto.
Only those with older tv's may need to adjust the HDMI Colourspace, if you find the colours are washed out, or if the screen is Green or Pink, in which case changing the option to RGB or 4:2:0 should fix this.
The Autores option has been removed as it should never be required now, however if you still feel that you do need this option for some reason, then you will find it on the feeds under systemplugins section.
...From here:
OBH
5.3.0.16
- Fix Video Refresh issues with p50/60 and p24
- Various background updates and tweaks
...From here:
OBH
