You can update bootlader with #84D then use the image #84D
DM800 HD - ERR01 NO CA FOUND
- elprofesor
- Active Member
- Has thanked: 6 times
- Been thanked: 14 times
Re: DM800 HD - ERR01 NO CA FOUND
Many thanks for the answer Zaam. Do you recommend using the image from the link below by Marwen, or do you suggest using another image for bootloader version 84d?
https://www.cam-sats.com/dm800-clones-images/7351.htm
- Has thanked: 10114 times
- Been thanked: 1253 times
Use this one is best on the linkelprofesor wrote: ↑14 May 2023, 04:21 Many thanks for the answer Zaam. Do you recommend using the image from the link below by Marwen, or do you suggest using another image for bootloader version 84d?
"Join New Forum Satworld-forum.com"
