XStreamity Latest
- Has thanked: 14325 times
- Been thanked: 1629 times
XStreamity Latest
X-Streamity - Official Release.
V 4.01 - 07/03/2023
Fixed invalid playlists.txt location crash. It now gets reset if invalid.
Updated all the translation po files from source again, if anyone want to update their missing elements.
V 4.01 - 07/03/2023
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
Re: XStreamity Latest
XStreamity V4.02
Only a tiny update.
Amended location box callback, to prevent an openatv double open issue if changing playlist.txt location option. (hopefully not broke other images)
Tried to eliminate black screen freezes when zapping, by removing the stream log, and loading the picon after the stream. It seems to play alot better now.
Added in seagens UHD skin files.
ipk:
deb:
[/centre]
Only a tiny update.
ipk:
https://1fichier.com/?8q4tdx5y5ii8ah2aknnxCode: Select all
https://1fichier.com/?27lvfovsjdy3hau2qdozVU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.03
Minor update
Git updated
Minor update
Git updated
- enigma2-plugin-extensions-xstreamity_4.03_20230704_all.deb
- (4.46 MiB) Downloaded 180 times
- enigma2-plugin-extensions-xstreamity_4.03.20230704_all.ipk
- (5.84 MiB) Downloaded 185 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.05
Fix the latest unnecessary openatv crash.
Sorry slight correction to the last release.
I was calling in the newly named component for newer builds incorrectly.
- enigma2-plugin-extensions-xstreamity_4.05_20230809_all.deb
- (4.46 MiB) Downloaded 155 times
- enigma2-plugin-extensions-xstreamity_4.05.20230809_all.ipk
- (5.84 MiB) Downloaded 170 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.07
button 0 in streamplayer now refreshes the stream i.e. if its frozen on live - quite useful actually
(i have tried multiple ways of trying to automate this, even trying some of oottppxx quarterpound code. It still isn't working to my satisfaction. 0 is easier and simple)
and as epg importer gets confused if sources are named exactly name from different plugins. I have added in the option to turn off epg importer in playlist settings.
EPG importer is only actually required if your provider uses all or some custom sid satellite refs.
I would recommend deleting all xstreamity epg importer files first. Start a fresh.
Compressed some images saving a 1mb. I have not compressed the backgrounds because I like the clarity of them.
- enigma2-plugin-extensions-xstreamity_4.07_20230907_all.deb
- (3.56 MiB) Downloaded 137 times
- enigma2-plugin-extensions-xstreamity_4.07.20230907_all.ipk
- (4.84 MiB) Downloaded 172 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.08
Fixed the downloader file reference
Fixed the new epgimporter option not being saved
I haven't put in the 256 dreambox autoreconnect option.
- enigma2-plugin-extensions-xstreamity_4.08_20230909_all.deb
- (3.56 MiB) Downloaded 187 times
- enigma2-plugin-extensions-xstreamity_4.08.20230909_all.ipk
- (4.84 MiB) Downloaded 133 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.10
Just a few tweaks for the epg importer files.
- enigma2-plugin-extensions-xstreamity_4.10_202309010_all.deb
- (3.56 MiB) Downloaded 177 times
- enigma2-plugin-extensions-xstreamity_4.10.20230910_all.ipk
- (4.84 MiB) Downloaded 136 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.11
fixed a few images that had converted to index colour
added in those locationbox changes for dreambox
- enigma2-plugin-extensions-xstreamity_4.11_202309013_all.deb
- (3.53 MiB) Downloaded 151 times
- enigma2-plugin-extensions-xstreamity_4.11.20230913_all.ipk
- (4.87 MiB) Downloaded 130 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.13
fixed the custom_sid crash
- enigma2-plugin-extensions-xstreamity_4.13_202309016_all.deb
- (3.53 MiB) Downloaded 179 times
- enigma2-plugin-extensions-xstreamity_4.13.20230916_all.ipk
- (4.87 MiB) Downloaded 127 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
XStreamity V4.14
vti image fixes
vti image fixes
- enigma2-plugin-extensions-xstreamity_4.14_202309016_all.deb
- (4.88 MiB) Downloaded 165 times
- enigma2-plugin-extensions-xstreamity_4.14.20230916_all.ipk
- (6.32 MiB) Downloaded 133 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
