Wallshow - Wallpaper Slideshow. Wallpaper changer. v21.7.23 [Pro]
Overview: Wallshow allow you to set auto change slideshow or wallpaper for Lockscreen and/or Home screen with a super easy step.
Just set your phone wallpaper slideshow by folders and/or picture collection and done.
Or set lock screen wallpaper with just 1 click.
(Lock screen feature is only supported for Android 7 or higher)
Slideshow intervals: 5s, 10s, 30s, 1min, 2mins, 3mins, ... 15mins, ..., everyday
Change picture when screen is turned on or unlocked as your desired.
Support SDcard and Night mode
WALLPAPER WIDGET
If you want to next wallpaper, don't worry the Wallshow wallpaper widget will help you with that. Just add it to your screen, click on it to go to next wallpaper.
EASY MANAGER
Add or remove photo or folder is super easy. Everything will then play automatically for you. If you want to temporarily disable a photo, do it just one click with our Wallpaper Playlist, the photo will be exclude from the playlist for you.
SHUFFLE WALLPAPER
Shuffle you wallpaper playlist. Auto change wallpaper by 5s, 10s, ..., 15 minutes, 30 minutes, 1 hour or everyday,... whatever you desire.
MATERIAL SLEEK DESIGN
Wallshow is designed for easily managing your screen wallpaper. Easy to select your folders or any photos you want to show on your screen.
Let's beautify our device screen with Wallshow wallpaper slideshow.
Give us 5 stars if you like the app. Don't hesitate to leave it a review ;).
Rate us 5 stars to support our development.
- Remind user to turn on Autostart permission so that the app won't be stopped unexpectedly and works properly
This app has credit advertisements
https://uploadrar.com/ohn8uqpvt8hv
