FileZilla Latest Version/Update
- sugar
- Has thanked: 73 times
- Been thanked: 1672 times
Re: FileZilla Latest Version/Update
FileZilla Server v1.7.0-rc2 Released
New Update: 28.04.2023
Bugfixes and minor changes:
-Small updater improvements..
-Print error message in log if hostname lookup fails while preparing data connection for passive mode..
-Fixes for login request throttler..
Download FileZilla Server v1.7.0-rc2
https://filezilla-project.org/download. ... ype=server
- sugar
FileZilla Server v1.7.1 Released
New Update: 26.05.2023
UI: Fixed session list rendering issues on Windows..
Banning an IP now also automatically kicks sessions with that IP..
Download FileZilla Server v1.7.1
- sugar
FileZilla Server v1.7.2 Released
Quote
New Update: 07.06.2023
Fixed handling of the "processing" order status when creating Let's Encrypt certificates..
Fixed an issue with sessions getting kicked if settings were applied..
Download FileZilla Server v1.7.2
Quote
- sugar
FileZilla Client v3.66.0-rc1 Released
New Update:11.10.2023
-Fixed crash removing items from the list of file extensions treated as text files..
-Fixed potental crash if shutting down HTTP client.
-Fixed HTTP timeouts..
Download FileZilla Client
https://filezilla-project.org/download. ... l=1&beta=1
- sugar
FileZilla Client v3.66.0 Released
Quote
New Update:23.10.2023
-Fixed a sorting issue in comparative search..
https://filezilla-project.org/download.php?show_all=1
Quote
- sugar
FileZilla Client v3.66.1 Released
New Update:03.11.2023
macOS: Fixed display of local filenames containing non-ASCII characters if LC_CTYPE wasn't set..
- sugar
FileZilla Server v1.8.0-rc2 Released
New Update:16.11.2023
-Fixed vulnerabilities:
-Fixed regression related to path handling..
-Fixed off-by-one buffer overflow in handling of IPV6 addresses..
New features:
-Admin UI: sessions IPs and user names can now be independently copied into the clipboard..
-Added option to disable the automatic renewal of Let's Encrypt certificates..
-Fixed bug in the updater that caused it to report new beta releases even if explictly told not to..
-User-provided certificates are now tested before being applied, so that the server always stays in a functioning state..
-Fixed potential issues in the impersonator process..
Download FileZilla Server v1.8.0-rc2
New features:
- sugar
FileZilla Client v3.66.3 Released
New Update:07.12.2023
New features:
macOS: Now also distributing aarch64 binaries..
macOS: Fixes for language detection..
Fixed a potential crash in the HTTP client..
New features:
- sugar
FileZilla Client v3.66.3-rc1 Released
New Update:11.12.2023
Test release for macOS CPU architecture migration..
- sugar
FileZilla Server v1.8.1. Released
New Update:25.01.2024
New features:
Limits to the number of active sessions defined for the groups now apply to the group as a whole, not just to the individual users belonging to those groups.
Fixed bug that led to timeouts not being set at startup, but only when changing the configuration.
FTP Server: NLST would report a file names with a leading ./ path in certain cases, which confused some clients. Fixed.
UI: Fixed bug that caused the Administration Interface to misinterpret native paths in the mount lists in case the server were running on a machine with different path semantics than the Administration Interface's one.
UI: fixed regression that led to some message dialogs not being displayed.
Fixed regression that caused disabled mount points with empty native paths to be discarded.
Fixed conversion to utf8 of virtual paths, which was wrongly misinterpreting some native encodings.
In case of login failure, the login timeout resumes counting down for the remaining time.
Download FileZilla Server v1.8.1
New features:
- 3 Replies
- 7801 Views
- 14278 Views
- 1577 Views
- 1341 Views
- 673 Views
- 142 Views
- 423 Views
- 553 Views
- 412 Views
- 2511 Views
