Edision OS Nino Plus OSCAM Help
Multics config Download & Config Profiles
The Founder
Has thanked: 10123 times
Been thanked: 1255 times
Re: Edision OS Nino Plus OSCAM Help
#11
Post by The Founder »
Iznogoud wrote: 01 Jan 2023, 23:21 Thanks for the help so far.
I'm a little lost at this stage, as there are several options and I don't know which one to choose in order to be compatible.
I have already tried one of them, with the following steps.
1 - I downloaded the plugin.
2 - Replaces the arm file and kept the original file name
3 - Replace oscam.conf, oscam.user and oscam.server files
4 - I restarted the box
5 - I was not successful in decoding the channels
How do you think I can move forward?
Install 1st oscam stable
Also share me which provider you want to watch??
Iznogoud
Has thanked: 3 times
Been thanked: 13 times
Portugal
#12
Post by Iznogoud »
Hi
Our provider it's MEO our VODAFONE our NOS in Portugal.
HISPASAT 30W
Iznogoud
Portugal
#13
Post by Iznogoud »
I uninstalled the plugin I had installed.
I restarted the BOX
I installed the plug in first that said Stable, followed the previously described process and was unsuccessful.
some print screens
The Founder
#14
Iznogoud wrote: 02 Jan 2023, 00:47 I uninstalled the plugin I had installed.
I restarted the BOX
some print screens
Use default configuration oscam
Just past reader
Reboot oscam
Iznogoud
Portugal
#15
Post by Iznogoud »
The Founder wrote: 02 Jan 2023, 01:22
I restarted the BOX
some print screens
Just past reader
Reboot oscam
Sorry, I do not understand
What you mean with "Just past reader"?
The Founder
#16
Iznogoud wrote: 02 Jan 2023, 03:02
I restarted the BOX
some print screens
Just past reader
Reboot oscam
Reader mean your connection which you buy from service holder
Iznogoud
Portugal
#17
Post by Iznogoud »
Hi
They send me a couple of files
Two Arm files
- oscam-svn11714-arm_dream-webif-dvbapi-ssl-emu798 (when i past this file to right folder I change the name to the original name. They inform that this works for 80% of the decoders, if not to use the following one)
- oscam-svn11714-mipsel_s3_ssl102-webif-dvbapi-ssl-emu798
(I test the both individually) and kept the original file name
and they send too
oscam.conf
oscam.user
oscam.server
The Founder
#18
Iznogoud wrote: 02 Jan 2023, 14:52 Hi
Two Arm files
and they send too
oscam.conf
oscam.user
oscam.server
install oscam from plugins and replace only oscam.server
reboot and enjoy
Iznogoud
Portugal
#19
Post by Iznogoud »
The Founder wrote: 02 Jan 2023, 15:04
Two Arm files
and they send too
oscam.conf
oscam.user
oscam.server
reboot and enjoy
Hi
now i've made
1 - uninstall the PlugIn
2 - Reboot
3 - Install again the plugin First Stable one that show
4 - Reboot
5 - replace the oscam.server only
6 - Reboot
7 - keep's not working... :cry:
something keeps not working
Some Printscreens and
logs
I contacted my provider and it keeps telling me the service is working fine
Caids 1810 , 1802 , 1814 , 0100
The Founder
#20
Iznogoud wrote: 03 Jan 2023, 00:07
Two Arm files
and they send too
oscam.conf
oscam.user
oscam.server
reboot and enjoy
Hi
now i've made
2 - Reboot
4 - Reboot
6 - Reboot
logs
Empty file why 🫢🫢
oscam.server 0kb it mean no data
I send you my server oscam.server file test it check pm box
Just copy all test and past in the oscam.server and save
After move oscam.server to box via dcc and tell me the result
