Overview: VentoX IPTV application is perfect & totally free solution for IPTV, EPG, VOD, Video series, Catch-up TV directly on your Android TV, Fire TV & Stick, Android Box, Android Tablets & Android Mobile.
VentoX IPTV Player application feature:
- Add Playlist from website and mange it
- 4K Content support , Subtitles and Dual Audio Supports to change Audio Language
- Custom User Agent Support for M3U and Single channels as well
- Quick WIFI & Setting Options
- Fast Play , Fast Zapping
- Private Video Movies and Shows
- Easy Up Down Live TV Switch
- Quick Easy Home Layout
- Universal Favorite to get all Favorite at one page
- Parental Control to lock channels and category
- Universal Search, for Movies , Live TV and Shows
- Play with Any Video Player
- Recent Playlist
- Easy Navigation while Playing Live TV
- Xtream Code API supports
- STB EMU supports
- Inbuilt best video player
- Supported devices: Chromecast β’, DLNA, Fire TV and Roku Tv
- Srt and Vtt subtitle support for cast devices
- Special compatibility mode for all DLNA devices. (This feature eliminates connectivity and codec problems.)
- Supports Multiple format file
- Video Caption supports
- User friendly, attractive, easy to navigate layout
- Use this application as launcher in your android tv
- Parental control to Lock/Unlock channels
- Support any external video player to play anything in app
- user can add and manage url from website and it sync with multiple device
What's new:
- Improvements Made
- We Supported Details of Content in Movies and Series.
- Added Live TV, Movie and Series Search Feature.
- Added 5 Device Support to Premium Subscription.
- Added Software Audio Codec Support.
- Performance Improvements Made.
Package Info:
β Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, tr-TR, uk, ur, uz, vi, zh-CN, zh-HK, zh-TW, zu;
β Supported CPU architecture: Armeabi-v7a, Arm64-v8a, X86, X86_64, Mips;
β Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Mod Info:
β Premium Subscription Unlock.
β A Skip App Introduction.
β All Unnecessary Setting & Home Screen Item Remove Like:
- How To Use, Privacy Policy, Chat Message, Account Detail, Premium Info, Feedback, About.
β Ads Removed / Disabled.
β Ads Related Activity & Code Removed / Disabled.
β Ads Related Layouts Visibility Gone.
β Analytics / Crashlytics Removed / Disabled.
β Receivers and Services Removed / Disabled.
β Google Play Store Install Package Check Disable.
β In-App Billing Service Removed / Disabled.
β Play Services, Transport, Firebase Properties Removed.
β All Unnecessary Garbage Folder & File Removed.
β Duplicate Dpi Item Remove Like:
β Splits0 File Removed (Resources & AndroidManifest).
β Splits0 Releated Unnecessary Meta-Data Remove Like:
β Optimized PNG Save To 230 Kb.
β Optimized JPG Save To 381 Kb.
β Re-Compressed Classes.dex & Library.
β Optimized Graphics / Zipalign.
β Removed Debug Information (Source, Line, Param, Prologue, Local).
β Total Apk Size 20.8 Mb.
http://ul.to/pext395s
