IPTV Live M3U8 Player v1.1.7 [Mod]
Requirements: 7.0+
Overview: IPTV player app supports M3U8 downloader, XSPF, M3U formats, live stream, Android TV Chromecast & Google cast. Watch free IP television in high quality. Live player compatible with IP TV box.
IPTV Player M3U8
- Create your own playlists like sport TV, news, BBC, etc.
 Functionality
- Simple TV guide.
- Live streams & record telecasts.
- Create playlists in free TV player using M3U8, XSPF, M3U & Web URLs.
- Rename & share your playlists.
- Download Web IPTV smarters programs on the fly.
- You can add online TV live player channels to the favorites.
IPTV Player
- Advantages
- IP television app supports Chromecast.
- Free M3U player IPTV pro.
- Picture in picture.
 Support Android TV.
- Live media player is lightweight.
- Live stream video M3U player is regularly updated.
- IPTV Pro playlist M3U8 is available in multiple languages.
- Use dark or light mode.
What's new:
- Implemented new feature - Sport Events! You have an opportunity to follow sport events you like and get notification about favorite events to watch them on time
- Implemented new feature - Categories! You can switch categories inside your playlists
- Fixed some bugs
- Added new design improvements to make it better for you
Package Info:
● Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-419, es-ES, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, id, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, uk, ur, uz, vi, zh-CN, zh-HK, zh-TW, zu;
● Supported CPU architecture: Armeabi-v7a, Arm64-v8a, X86, X86_64;
● Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Mod Info:
● Premium Feature Unlock.
● A Skip App Introduction.
● Ads Removed / Disabled.
● Receivers and Services Removed / Disabled.
● Google Play Store Install Package Check Disable.
● In-App Billing Service Removed / Disabled.
● Duplicate Dpi Item Remove Like:
● Splits0 File Removed (Resources & AndroidManifest).
● Splits0 Releated Unnecessary Meta-Data Remove Like:
● Optimized PNG Save To 3230 Kb.
● Optimized JPG Save To 381 Kb.
● Re-Compressed Classes.dex & Library.
● Optimized Graphics / Zipalign.
● Total Apk Size 156 Mb.
https://uploadrar.com/t6v8qk9om7vo
leonkey
Been thanked: 1 time
United States of America
Re: IPTV Live M3U8 Player v1.1.7 [Mod]
Post by leonkey »
First, you need to find a reliable and trustworthy website that offers modded APKs. Make sure to choose a reputable website to avoid downloading malware or harmful apps that can harm your device. Once you find the website, search for "Pikashow MOD APK[/url]" in the search bar, and you will get the download link for the modded version of the app.
vanbeek
India
Post by vanbeek »
Try the split-screen trend by dividing your video into two or more sections. Each section can display different footage simultaneously, allowing you to show multiple perspectives or compare contrasting elements. provides split screen templates that you can customize with your own videos and adjust the sizes and positions of each section.
kellywilkerson
Post by kellywilkerson »
You must first locate a trustworthy and reputable source that sells modded APKs. Make sure to select a trustworthy website to prevent downloading malicious software or apps that can damage your smartphone. When you arrive at the website, type "Pikashow MOD APK" into the search field to discover the download link for the app's modded version.
akhmed354
Post by akhmed354 »
IPTV Smarters Pro is a versatile and superior media application to bring users a wealth of information or novel content worldwide. However, it is limited to IPTVs already provisioned in the user’s area, but they can now access everything through their device for absolute mobility. People can also create multiple user profiles to enjoy perfectly personalized experiences
edithschwab
Post by edithschwab »
IPTV Live M3U8 Player v1.1.7 [Mod] is an application that allows users to play IPTV streams using M3U8 playlists. The term "indicates that this version of the app has been modified, possibly to offer additional features or remove restrictions present in the original version.
Please note that I cannot provide specific download links or access to copyrighted material or modified Pikashow mod APK applications. It's essential to respect intellectual property rights and use software legally and ethically. If you're interested in using IPTV services, make sure to subscribe to legitimate services and use official apps available on authorized platforms.
etersonsmith
Been thanked: 2 times
Post by etersonsmith »
Thank you so much for this detailed overview. I want to add just a little bit. If you want to download all these stuff in a premium quality you can download pikashow apk. I have used it to download all of my favorite movies, tv shows and matches.
amir
Post by amir »
HVAC installation involves positioning heating, ventilation, and air conditioning systems for efficient climate control.
Skilled technicians consider factors like system sizing and local codes to ensure a tailored and energy-efficient solution.
Learn more about HVAC on tempo.
amir
Post by amir »
sajida asif
Post by sajida asif »
You're welcome! That sounds like a convenient option for accessing premium content. Pikashow apk seems like a great solution for downloading your favorite movies, TV shows, and matches in high quality. Thanks for sharing!
