TikTok v23.7.3 (Unlocked)(Mod)(Plugin)
Been thanked: 1027 times
Requirements: 4.4+
Overview: TikTok is THE destination for mobile videos. On TikTok, short-form videos are exciting, spontaneous, and genuine. Whether you’re a sports fanatic, a pet enthusiast, or just looking for a laugh, there’s something for everyone on TikTok.
★ Mods-
- Removed InVideo Google ads
- Made video and GIF downloading without watermark to Movies/TikTok folder instead of DCIM/Camera
- Removed all restrictions on downloads, you can download any video
- Removed all other restrictions (many)
- The application was cleaned as much as possible, duplicate graphics removed
- Optimized graphics
- Maximum compression + ZipAlign
- Disabled unnecessary activities
- Removed restrictions on duets, stitching and dynamic wallpapers
- Rewind is now available in any video
- Battery drain optimization
- Remove most of regional restrictions
- Fixed Facebook authorization
- Fixed VK authorization
- Disabled autostart
- Enabled High Quality Audio
- Enabled High Quality Video
- Enabled Ultra Resolution
- Enabled Anti Aliasing
- Disabled wakelocks
- Hidden root rights
- Disabled InAppBillingService
- Disabled all types of Analytics
- Disabled Measurement.
What's New-
- Code improvements
- An attempt to make duets and stitching available
★ Exclusively Modded By DMITRY Nechoporenko
★ Plugin For TikTok Features-
- Details for regions (Long press on Region option)
- Option for matching post's region with selected region. (Don't show post's that are not related to selected region)
- Option for hide ads from trending list in discover section
- Option for disable playing videos in loop behavior
- Option for hide live streams from timeline
- Option for hide post captions from everywhere
- Option for hide long posts (with custom length) from timeline
-Ability to change download directory
- Ability to make keyword blocklist for captions (Post's with specific words will not appear in timeline)
- Remove Video watermark & GIF watermark options
- Ability to bypass duet & stitch privacy settings
- Theme switcher for plugin
- Added new speeds in playback speed option. (1.25x, 1.5x, 2.25x, 2.5x)
- Option for downloading videos without sound (Mute videos will save with mute.mp4 prefix)
- Option for changing font style (Currently support 6 new font + default)
- Option for changing ui colors like main bottom background color
- Added ability to reset plugin settings (Menu > Reset)
- Tap app bar for navigating to top of the options list
- Long press on options to see more info
★ v2.2.8 Changelog-
- All regions have been checked and sorted alphabetically (thanks David)
- Corrected translations, also added new ones from Crowdin
★ Exclusively Developed Till v2.2.0 By SAEEDStarv
★ Exclusively Redeveloped Further By DMITRY Nechoporenko
★ Note1- Working in Banned Countries, Tested in India, Vpn is required if tiktok server is blocked from your isp dns.
★ Note2- If you face "Too Many Attempts" Error on login, Use Forgot Password Option.
We've got new stickers to try in this release—check 'em out!
This app has credit advertisements
http://ul.to/ekdrzk0h
eddiehere34
Been thanked: 1 time
Albania
Re: TikTok v23.7.3 (Unlocked)(Mod)(Plugin)
Post by eddiehere34 »
Hmm, I'm using this tiktok version. Its Awesome.
