[Plugin] OpenWebif
- sugar
- Has thanked: 73 times
- Been thanked: 1652 times
Re: [Plugin] OpenWebif
18.08.2022
Version 1.5.2 with Latest Fixes
● Update
● Fix Traceback due to undefined key "config.usage.date.displayday.value" inn EPG
● Separate EPG
* Remove redundant eEPGCache import, remove event field comments
* Add message for missing function parameters
* Add event functionality comments
* Set defaults for optional parameters
* Cast parameter values to expected types
* Consistent separation of criteria eventFields
* Utilise `getEventById` to getEventDescription
* Remove unnecessary sub-bouquet exclusion; simplify endTime query
* Consistent debuggery
* Build event data
* Use `lookup event by time` for `getChannelNowEvent` and `getChannelNextEvent`
* Simplify to `NOW_EVENT`/`NEXT_EVENT` const names
* Consolidate similar functions while preserving façades
* Transition to epgEvent object referencing
* Smarter Nonery, consolidated date formatting to function, fuzzy duration/remaining text
* Remove EPGCache comments which were useful during dev
* Privatise some functionality
* Add `start`/`end` time formats (`today/tomorrow` and `iso`)
* Remove hardcoded testing value
* Move internal functions back into class
* Separate lookup fields from criteria
* Change event fields to consts
* Simplify getting list of bouquet services
* Improve EPG lookup result `event` structure,
Add fuzzy date formats ('Tomorrow...')
Add fuzzy time formats ('1 hr 15 mins'),
Remove development comments
* Smarter logging
* Revamp EPGEvent result processing
* Improve process debug timing
* Separate EPGEvent class
* Consistent file encoding header
* Capitalise `Epg()` -> `EPG()`
* Use absolute import
* Catch None epgEvents
* Workaround for 'tuple' object has no attribute 'toJSON'
* Temporarily comment out performance measuring
* EPG test page - /ajax/epgplayground
● Update
● Separate EPG
* Build event data
* Smarter logging
- enigma2-plugin-extensions-openwebif_1.5.2-git20220818-r6_vti.ipk.rar
- (4.9 MiB) Downloaded 20 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20220818-r6_all.ipk.rar
- (12.49 MiB) Downloaded 19 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20220818-r6_all.deb.rar
- (3.46 MiB) Downloaded 18 times
- sugar
27/11/2022
Add sfx60x8 picture, remote
enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_all.deb (3.46MB)
enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_vti.ipk (4.90MB)
enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_all.ipk (12.58MB)
- enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_all.ipk
- (12.58 MiB) Downloaded 31 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_vti.ipk
- (4.9 MiB) Downloaded 32 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20221127-r2_all.deb
- (3.46 MiB) Downloaded 28 times
- sugar
Open Webif Plugin..09/12/2022
- Ver 1.5.2 with Latest Fixes
- Fix indentation errors
- Added Octagon SFX6018
- enigma2-plugin-extensions-openwebif 1.5.2-git20221209-r3 all.ipk
Revealed content
https://sbupload.com/1fe57231706bedc2
- enigma2-plugin-extensions-openwebif 1.5.2-git20221209-r3 vti.ipk
Revealed content
https://sbupload.com/051ef8a6b677f0be
- enigma2-plugin-extensions-openwebif 1.5.2-git20221209-r3 all.deb
Revealed content
https://sbupload.com/95ba29a2227cc016
Revealed content
Revealed content
Revealed content
- sugar
OpenWebif plugin edit by (RAED) to DreamOS image OE2.5/2.6.
Version 1.6
P.s: You need first to install wget before install plugin
apt update && apt install wget -y
To install plugin directly online from telnet be this command
Code:
wget https://raw.githubusercontent.com/fairb ... staller.sh -O - | /bin/sh
Version 1.6
Code:
- sugar
27/12/2022
Fix for Progressbar doesn´t work …
Percentage is computed using integers, thus division by duration was always 0.
- enigma2-plugin-extensions-openwebif_1.5.2-git20221227-r3_vti.ipk
- (4.91 MiB) Downloaded 24 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20221227-r3_all.ipk
- (12.71 MiB) Downloaded 23 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20221227-r3_all.deb
- (3.61 MiB) Downloaded 21 times
- sugar
02/01/2023
Fix edit timer from multiepg
- enigma2-plugin-extensions-openwebif_1.5.2-git20230102-r7_all.ipk
- (12.71 MiB) Downloaded 27 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230102-r7_vti.ipk
- enigma2-plugin-extensions-openwebif_1.5.2-git20230102-r7_all.deb
- (3.61 MiB) Downloaded 29 times
- sugar
06/01/2023
[DreamOne/Two] Add support it
- enigma2-plugin-extensions-openwebif_1.5.2-git20230106-r2_all.ipk
- (12.85 MiB) Downloaded 24 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230106-r2_vti.ipk
- (4.91 MiB) Downloaded 22 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230106-r2_all.deb
- (3.67 MiB) Downloaded 27 times
- sugar
5/01/2023
bump future from 0.18.2 to 0.18.3 in /CI
Get rid of getConfigListEntry()
[Dreamone/Two] Fix detect procmodel
Revealed content
enigma2-plugin-extensions-openwebif_1.5.2-git20230115-r6_all.deb https://www52.zippyshare.com/v/nl5eSU6O/file.html
enigma2-plugin-extensions-openwebif_1.5.2-git20230115-r6_all.ipk https://www52.zippyshare.com/v/Qp69Ofal/file.html
enigma2-plugin-extensions-openwebif_1.5.2-git20230115-r6_vti.ipk https://www52.zippyshare.com/v/JSfNmcGw/file.html
Revealed content
- sugar
21/01/2023
improve getCurrentFullInfo if epg is empty
- enigma2-plugin-extensions-openwebif_1.5.2-git20230121-r2_all.ipk
- (12.86 MiB) Downloaded 23 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230121-r2_vti.ipk
- (4.92 MiB) Downloaded 24 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230121-r2_all.deb
- (3.67 MiB) Downloaded 25 times
- sugar
22/01/2023
* fix epgrefreh toUnixDate
* fix epgrefresh save begin/end
- enigma2-plugin-extensions-openwebif_1.5.2-git20230122-r6_all.ipk
- (12.86 MiB) Downloaded 26 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230122-r6_vti.ipk
- (4.92 MiB) Downloaded 22 times
- enigma2-plugin-extensions-openwebif_1.5.2-git20230122-r6_all.deb
- (3.67 MiB) Downloaded 23 times
- 274 Views
- 3 Replies
- 1320 Views
Last post by kingsman
- 545 Views
- 923 Views
- 4 Replies
- 569 Views
Last post by piplan1966
- 3 Replies
- 899 Views
- 447 Views
Last post by kausarnasir
- 995 Views
- 329 Views
- 255 Views
