Oscam 11714 with emu 798 patch icam
Been thanked: 1667 times
fix for Viaccess EMM Update < V7 broken
zapppa
Has thanked: 43 times
Been thanked: 86 times
Italy
Re: Oscam 11714 with emu 798 patch icam
Post by zapppa »
Only some channel works for me
lider
Been thanked: 994 times
Post by lider »
fine work any channel thanls
gintarasarm
Has thanked: 1 time
Been thanked: 5 times
Lithuania
Post by gintarasarm »
Hi, which of them oscam emu will work on vu+ duo4kse OpenBH ARM architecture?
gintarasarm wrote: ↑18 Oct 2022, 20:12 Hi, which of them oscam emu will work on vu+ duo4kse OpenBH ARM architecture?
If work 100% you can install correct way
gintarasarm
Has thanked: 1 time
Lithuania
You did not understand me, I ask which emu will work with ARM architecture: 1 number (first emu), 2 number (second emu), 3 number(third emu) and so on...Because you gave 8 number emu, that's why I'm asking which emu?
Rizwan awan
Has thanked: 41 times
Been thanked: 425 times
Post by Rizwan awan »
gintarasarm wrote: ↑18 Oct 2022, 20:43 You did not understand me, I ask which emu will work with ARM architecture: 1 number (first emu), 2 number (second emu), 3 number(third emu) and so on...Because you gave 8 number emu, that's why I'm asking which emu?
last one with vuplus4k-ARM
Wetek Play2
Octagon SF8008
Vu+ Solo2
Dreambox 800HD
lider
Post by lider »
mucahitdogan68
Has thanked: 10 times
Been thanked: 6 times
Post by mucahitdogan68 »
Dreamstar Master Plus cihazına bu oscam sürümü kursak cihazda çalışırmi acaba.
Return to “Oscam”
