Requirements: 4.2+
Overview: This is an Android TV application that can be launched not only on profile Android TV set-top boxes, but also on regular TV-Box with Android version above 4.2.
The application is designed for online viewing of movies and TV shows from popular resources. Flexible settings allow you to customize the interface to your needs.
Attention! The application is only for devices with remote control. Touch interface initially does not work correctly, because leanback library is used.
To view from TREE.TV you need to install mxplayer. This is a temporary, but still necessary condition.
I want to note that this is the alpha version of the application. If possible, describe all the bugfixes in this thread with the type of device, the version of android, the version of the application.
★★★ MOD ★★★
PRO Unlocked
Ads Removed
Analytics Removed
Auto-update Disabled
What's New
• [TV][TOUCH] kinovod service added;
• [TV][TOUCH] added tracker rutracker.ru;
• [TV][TOUCH] removed tracker underverse (links are not available without registration);
• bug fixes;
http://ul.to/64zw8lk0
