Smart TV Remote: Smart ThinQ v4.4 [Premium]
Been thanked: 1028 times
Requirements: 7.0+
Overview: LG Smart TV Remote helps you control your TVs from the comfort of your phone.
This LG TV Remote App is compatible with all LG Smart TVs with WebOS.
Quick Cast To TV and Share Photos & Videos in high-definition from your Gallery directly onto your devices with the tap of a button on the dedicated ""Cast"" tab. Search effortlessly by using the keyboard or voice-to-text commands.
Enjoy quick access to your favorite media apps like Prime Video, Netflix, Hulu, YouTube, HBO, Fite and others with the dedicated ""Apps"" Tab. This Smart TV Remote also helps you use swipe-based gestures on your devices for easier navigation.
This Universal Remote LG app is the prime way for you to watch & cast to TV conveniently.
Features:
+ Intuitive remote control.
+ Quick access to your favorite apps and channels.
+ SmartCast feature: Cast media directly from your library.
Setup: Please connect both devices to the same WiFi network. Select your LG Smart TV in the app and, when prompted, ""Allow"" the app. That's it! Simple, quick, with complete features.
DISCLAIMER: This TV Remote For LG application is not affiliated with nor endorsed by LG Electronics, Inc. and it is not an official product of it or of its affiliates.
(Please note that this application cannot turn on your TV. Your TV is not connected to WiFi when it is OFF, so it can't accept commands.)
Better design for your app & bug fix.
http://ul.to/126fg9rz
