Motor Feed Settings© by Morpheus883 [*.Settings² ]
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
Enigma 2 Settings 28th March 2022 © by Morpheus883:
Settings for Images based on Enigma 2.4
First Settings with full support for Multiple Input Streams (MSI) & DVB-S2X*:
Statistics:
# Satellites: 90 (Ku Band)
# Ordered Provider Lists: 70+
# Services: 16.778 (TV-Radio-Data)
# Packages: 23 (TV-Radio-Data):
MONOFeed (13°E)
DUALFeed (13°E + 19.2°E)
HISPASAT 30W DUALFeed (30°W + 13°E)
HISPASAT 30W TRIALFeed (30°W + 13°E + 19.2°E)
THOR 5/6/7 DUALFeed (0.8°W + 13°E)
THOR 5/6/7 TRIALFeed (0.8°W + 13°E + 19.2°E)
ASTRA 4 DUALFeed (4.8°E + 13°E)
ASTRA 4 TRIALFeed (4.8°E + 13°E + 19.2°E)
EUTELSAT 9 DUALFeed (9°E + 13°E)
EUTELSAT 9 TRIALFeed (9°E + 13°E + 19.2°E)
EUTELSAT 16 DUALFeed (13°E + 16°E)
EUTELSAT 16 TRIALFeed (13°E + 16°E + 19.2°E)
ASTRA 3B DUALFeed (13°E + 23.5°E)
ASTRA 3B TRIALFeed (13°E + 19.2°E + 23.5°E)
ASTRA 2E/2F/2G DUALFeed (13°E + 28.2°E)
ASTRA 2E/2F/2G TRIALFeed (13°E + 19.2°E + 28.2°E)
TURKSAT 3A/4A DUALFeed (13°E + 42°E)
TURKSAT 3A/4A TRIALFeed (13°E + 19.2°E + 42°E)
THOR 5/6/7 ASTRA 4 TRIALFeed (0.8°W + 4.8°E + 13°E)
THOR 5/6/7 ASTRA 2E/2F/2G QUADFeed (0.8°W + 13°E + 19.2°E + 28.2°E)
EUTELSAT 16 ASTRA 3B QUADFeed (13°E + 16°E + 19.2°E + 23.5°E)*NEW Special Edition
ASTRA 3B/2E/2F/2G QUADFeed (13°E + 19.2°E + 23.5°E + 28.2°E)*NEW Beta Edition
Motor - FULLFeed (45.0°W - 76.5°E)
OTHER PACKAGES AVAILABLE ON REQUEST
*Multiple Input Streams (MIS):
Implemented full support for Multistream Transponders on 30.0°W, 12.5°W, 5.0°W, 9.0°E, 21.6°E, 39.0°E, 52.5°E sat orbs: added complete extensions both in lamedb and satellites.xml.
Basic support for T2-MI MS Transponders on 4.8°E.
Running on specific images/FW/HW only: install them directly or with E2 Editors with MIS extensions.
*DVB-S2X Transponders:
Added Transponders broadcasting new advanced DVB-S2X standard on 0.8°W, 19.2°E, 33.0°E sat orbs.
Running only with specific tuners/demodulators.
Any feedback would be greatly appreciated (pls specify stb model, FW, etc.)! Thank you in advance for taking the time to help me on this test wink.gif
The only settings with BlindMarke®
BlindMarke®s are services specifically created for difficult/unexplored constellations, useful for pointing dish to difficult sats with the USALS/DiSEqC 1.2 support.
Easy instructions:
1. Open "Sat Pointer" folder
2. Select the BlindMarke® you desire in order to move your dish on the desired orbital position
3. Once achieved, you can start blindscan or switch to C tuner
https://anonfiles.com/h8eaC7Rdx9/E2_Mor ... 280322_zip
Statistics:
MONOFeed (13°E)
Easy instructions:
- sugar
Re: ✅⇨ E²_Motor Feed Settings© by Morpheus883 [*.Settings² ] 🔥
Enigma 2 Settings 1st April 2022 © by Morpheus883:
Statistics:
# Services: 16.842 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
=== Compiled with Morpheus883's scripts ===
======= © by Morpheus883, 2022 =======
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_010422.zip
- (2.59 MiB) Downloaded 251 times
- sugar
Enigma 2 Settings 4th April 2022 © by Morpheus883:
Statistics:
# Services: 16.874 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_040422.zip
- (2.59 MiB) Downloaded 207 times
- sugar
Enigma 2 Settings 8th April 2022 © by Morpheus883:
Statistics:
# Services: 16.879 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_080422.zip
- (2.59 MiB) Downloaded 204 times
- sugar
Enigma 2 Settings 11th April 2022 © by Morpheus883:
Statistics:
# Services: 16.859 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_110422.zip
- (2.59 MiB) Downloaded 220 times
- sugar
Enigma 2 Settings 21st April 2022 © by Morpheus883:
Statistics:
# Services: 16.900 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_210422.zip
- (2.6 MiB) Downloaded 227 times
- sugar
Enigma 2 Settings 27th April 2022 © by Morpheus883:
Statistics:
# Services: 16.967 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_270422.zip
- (2.61 MiB) Downloaded 211 times
- sugar
Enigma 2 Settings 6th May 2022 © by Morpheus883:
Statistics:
# Services: 17.015 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
https://www.mediafire.com/file/a47c2e3p ... 2.zip/file
Statistics:
MONOFeed (13°E)
Easy instructions:
- sugar
Enigma 2 Settings 9th May 2022 © by Morpheus883:
Statistics:
# Services: 17.038 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_090522.zip
- (2.58 MiB) Downloaded 185 times
- sugar
Enigma 2 Settings 13th May 2022 © by Morpheus883:
Statistics:
# Services: 16.503 (TV-Radio-Data)
MONOFeed (13°E)
Easy instructions:
Statistics:
MONOFeed (13°E)
Easy instructions:
- E2_Morph883_Settings_130522.zip
- (2.55 MiB) Downloaded 172 times
