Sygic GPS Navigation
Sygic GPS Navigation - 20.7.4 - Premium/Extra MOD APK
How to install Sygic GPS Navigation & Maps v20.8.12-1769 APK + MOD (Premium Subscription) ?
Click on the saved APK file Sygic GPS Navigation & Maps v20.8.12-1769 APK + MOD (Premium Subscription) Since Android does not allow installation of APKs from unknown sources, please do as follows:
-> Open Sygic GPS Navigation & Maps v20.8.12-1769 APK + MOD (Premium Subscription).apk file, there will be a message like this:
-> Click Settings (Settings).
-> Click the Activate button (Activate).
-> Then go back and select the downloaded APK file. Click the Install button.
How to install the OBB file?
+ First of all, please download Sygic GPS Navigation & Maps v20.8.12-1769 APK + MOD (Premium Subscription) APK file first.
+ Copy the APK file to your device's SD card and install it. (Do not open it after installation)
+ Then download the Obb file and copy the *.obb file named '' to the required location:
/SDCARD/Android/obb/com.sygic.aura/
-> The full/absolute path of the obb file will look like this (remember it is case sensitive):
If you don't have such a folder, please create it manually on your SD card.
http://ul.to/wxlmwnlk
