IPTV Live M3U8 Player v1.1.1 [Mod]
Requirements: 7.0+
Overview: IPTV player app supports M3U8 downloader, XSPF, M3U formats, live stream, Android TV Chromecast & Google cast. Watch free IP television in high quality. Live player compatible with IP TV box.
IPTV Player M3U8
- Create your own playlists like sport TV, news, BBC, etc.
Functionality
- Simple TV guide.
- Live streams & record telecasts.
- Create playlists in free TV player using M3U8, XSPF, M3U & Web URLs.
- Rename & share your playlists.
- Download Web IPTV smarters programs on the fly.
- You can add online TV live player channels to the favorites.
IPTV Player
- Advantages
- IP television app supports Chromecast.
- Free M3U player IPTV pro.
- Picture in picture.
Support Android TV.
- Live media player is lightweight.
- Live stream video M3U player is regularly updated.
- IPTV Pro playlist M3U8 is available in multiple languages.
- Use dark or light mode.
What's new:
- Implemented new feature - Categories! Now you can switch categories inside your playlists
- fixed some bugs
- added new design improvements to make it better for you
Package Info:
● Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-419, es-ES, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, id, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, uk, ur, uz, vi, zh-CN, zh-HK, zh-TW, zu;
● Supported CPU architecture: Armeabi-v7a, Arm64-v8a, X86, X86_64;
● Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Mod Info:
● Premium Feature Unlock.
● Ads Removed / Disabled.
● Receivers and Services Removed / Disabled.
● Google Play Store Install Package Check Disable.
● In-App Billing Service Removed / Disabled.
● Duplicate Dpi Item Remove Like:
● Splits0 File Removed (Resources & AndroidManifest).
● Splits0 Releated Unnecessary Meta-Data Remove Like:
● Optimized PNG Save To 3230 Kb.
● Optimized JPG Save To 381 Kb.
● Re-Compressed Classes.dex & Library.
● Optimized Graphics / Zipalign.
● Total Apk Size 153 Mb.
http://ul.to/yhyvs4t0
Return to β€œMobile Zone”
