AdAway - No Root Ad Blocker v6.0.3-20220725 [Final]
Requirements: 8.0+
Overview: AdAway is an open source ad blocker for Android using the hosts file.
Description
AdAway is a utility used to manage hostfile entries. AdAway doesn't directly block ads; it limits unwanted ads by blocking servers that distribute those ads to websites. Modifying hostfile entries is also useful in blocking ads on some Android apps.
Add a new VPN ad-blocker implementation
Add initial DOH (DNS Over HTTPS) support
Add VPN connection monitor, heartbeat and throttler to improve reliability
Add long press action to copy hostname from user lists and DNS log to clipboard
Improve screen rotation handling on home screen
Improve hosts source cache to reduce bandwidth usage
Improve GitHub API usage to reduce bandwidth usage
Fix VPN state on network connectivity change and lost
Fix VPN restart when system kills it
Fix wrong DNS read on VPN restart
Fix VPN unwanted restart while paused
Fix crash on application update unknown size
Improve VPN user control reliability
Update logging system
Update libsu
Update mongoose web server
Update Android gradle plugin
Update AndroidX libraries
Update NDK
Update third party libraries
Update translations
Package Info:
Languages: Full Multi Languages;
CPUs: armeabi-v7a, arm64-v8a, x86, x86_64;
Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
Untouched [Paid] apk with Original Hash Signature, no [Mod] or changes was applied;
Certificate MD5 digest: 8f3fe3b846b7cd1eb31df5662a65fb16
http://ul.to/j0239e9a
