OsCam Changelots
Re: OsCam Changelots
New Update: 30.01.2025
Changeset 11868 (3d1130be)
* Fix compiler hangs on Ubuntu as dir command can't be used there..
Thx @ohmza
Thx @ohmza
New Release
Changeset 11870
* Fix unable to compile oscam with OpenSSL on FreeBSD
* Fix unable to compile oscam with pcsc on FreeBSD
Thx @ ohmza
Changeset 11870
Thx @ ohmza
New Release
Changeset 11878
thx tem_invictus
Resolve "Reduce CPU usage on using Newcamd"
* Fix build errors on EuroDes
* There is a performance issue of DES handling in Newcamd code.
1. While rightRot can be unrolled for tiny improvement, the leftRot implementation is a nightmare.
Instead of repeating rightRot 27 times, do it the proper way.
2. Also EuroDes is always called with the same desMode. As TestBit(desMode, F_TRIPLE_DES) always succeeds, drop Eurocrypt S2/M dead code.
thanks to lpm11
Co-authored-by: ohmza
Changeset 11878
thx tem_invictus
thanks to lpm11
New Release
Changeset 11880
css: fix skin and add hover
* css: fix skin and add hover
* Scan USB: optimize css table
* Status: small visual adjustments
* Status, Reader, User, Cacheex, Services: add mouse over effect
(thx @ uf2k + @ Karl Dall)
Thanks WXbet
Quote
11879
-Fix spelling errors on Readers Write EMM page
Changeset 11880
Thanks WXbet
Quote
11879
New Release
Changeset 11881
cmake: fix build with version 4.0.0
* update copyright year
* css fix white space and tab
thx @ heitbaum for cmake fix
Thx @ The Truth
Changeset 11881
Thx @ The Truth
- 3093 Views
Last post by dave007
- 2438 Views
- 4859 Views
- 108 Replies
- 27638 Views
Last post by VivaEuropeTV
- 11 Replies
- 11316 Views
