XStreamity v5.01_20250607
Fixed the messed up HD/UHD skins
German translation update
Page item count correction
Amended picon download timeout to 2 seconds
Added a delay to live player picons to speed up channel load
Removed unnecessary function call on live on selection change to speed things up
Added fat verticals to the name stripping.
Better regex to pick up the year from titles for TMDB use.
Pytube downloader for trailers - update
English POT file - source update
Removed the EPGimporter settings override - it was causing unnecessary memory usage for people who didn't require it.
if your provider uses epg satellite refs, please change the epgimporter settings manually.
LOAD EPG ONLY SERVICES IN BOUQUETS - turn off for most people. Turn on if provider has epg satellite refs. (basically if you have an xstreamity/xklass epg importer reference in sources. You need this on.
enigma2-plugin-extensions-xstreamity_5.01_20250607_all.deb
enigma2-plugin-extensions-xstreamity_5.01.20250607_all.ipk
X-Streamity - Xtream Codes IPTV Player (new thread)
- Been thanked: 2735 times
Re: X-Streamity - Xtream Codes IPTV Player (new thread)
XStreamity v5.02_20250607
Fixed a potential crash if genre was missing
enigma2-plugin-extensions-xstreamity_5.02_20250707_all.deb enigma2-plugin-extensions-xstreamity_5.02.20250706_all.ipk
mehmetkarahanlı
- Been thanked: 394 times
X-Streamity - Official Release.
V 5.04 - 14/07/2025 :face with monocle:
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies.
Then you can load the latest from this forum over the top.
Plugin is for playing official Xtream Codes/XUI ONE IPTV playlists.
This plugin does not play other playlists or m3u playlists.
enigma2-plugin-extensions-xstreamity_5-04-20250714_all
enigma2-plugin-extensions-xstreamity_5- ... 14_all_deb
- 5 Replies
- 6875 Views
Last post by p060477
- 7473 Views
Last post by sarlamun
- 315 Replies
- 198965 Views
Last post by 1dir1
- 1763 Views
Last post by mehmetkarahanlı
- 3107 Views
