OsCam Changelots
Re: OsCam Changelots
New Update: 01.11.2024
Changeset 11846 (ae6e55a9)
Irdeto and nagra cak7 with seca/nagra card bugs fix
* Fix 'get_emm_type() returns error' on CAK7 Seca/Nagra card..
* Fix some ECM error messages don't display properly..
Thx ohmza
Thx ohmza
New Release
New Update:13.11.2024
Changeset 11848 (37a283a7)
signing: build warning when using elliptic curve signature algorithms with OpenSSL versions before 1.0.0
* pipeline: use rsa signature algorithm for ancient toolchain..
Thx @WXbet
Thx @WXbet
11849-f3d8575c
13.11.2024
* Remove tivusat hardware global emm fix as it is not required anymore.
thanks ohmza
13.11.2024
thanks ohmza
New Update:14.11.2024
Changeset 11850 (f9b9c387)
FreeBSD support (thanks to khimtiki)
- Makefile, CMakeLists.txt, config.sh: use gdate + gnustat + gsplit as alternatives if available (coreutils package in FreeBSD)..
- config.sh: fix "xargs: unterminated quote" and "Bad substitution" errors in sh shells..
- globals.h: do not include sysmacros.h for FreeBSD..
- oscam-signing.h: adjust trust store location + filename by operating system..
Thx WXbet
Thx WXbet
Changeset 118451 (d08a0c2c)
- Add EMM filters on Seca/Nagra card..
Thx ohmza
Thx ohmza
New Update:15.11.2024
Changeset 11852 (7b970c25)
* Revert the change done to oscam-emm.c on 11806 back to the previous state..
Thx ohmza
Thx ohmza
Changeset 11853 (2c6646fe)
make: Fix missing newlines in buildlog
introduced in 11850 (f9b9c387)..
Thx @WXbet
Thx @WXbet
New Update: 17.11.2024
Changeset 11854 (386b2262)
* Add support Tongfang EMM..
Thx ohmza
Thx ohmza
New Update:18.11.2024
Changeset 11855 (8676f706)
Remove hard-coding CAIDs and switch to already built-in webif configuration
* Utilize already existed "Force Even SA" webif configuration instead of hard-coding CAIDs. For 1884 and 1856 cards, you must enable "Force Even SA" in order to have EMM working properly..
Thx ohmza
Thx ohmza
New Update:19.11.2024
Changeset 11856 (2e8b0cba)
Readd some CAK7 EMM processing code that was removed in 99e39871 and log improvement.
* Improve CAK7 log on T0 protocol card..
* Re-add CAK7 EMM processing code that was accidentally removed in 99e39871..
Thx ohmza
Thx ohmza
- 2401 Views
- 2495 Views
Last post by dave007
- 2163 Views
- 4749 Views
- 104 Replies
- 23425 Views
Last post by VivaEuropeTV
