Latest Version of OScam
kingsman
E2 Developer
E2 Developer
Has thanked: 13 times
Been thanked: 268 times
France
Re: Latest Version of OScam
#472
Post by kingsman »
oscam-git11904-802
oscam-git11904-802@d41bd68a-vusolo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.51 KiB) Downloaded 12 times
oscam-git11904-802@d41bd68a-vuplus4k_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.5 KiB) Downloaded 7 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#473
Post by kingsman »
oscam-git11905-802
Resolve "Loadbalancer - fallback adjustment"
* Allow lb_nfb_readers to be set to zero (previously minimum was 1). This means you can configure the system to have no fallback readers if desired.
* If only one reader matches and double_check is enabled (and the CAID matches), the patch forces a fallback check by setting force_reopen = 1.
oscam-git11905-802@0fd204fd-Linux-x86_64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-signed.zip
(864.76 KiB) Downloaded 4 times
oscam-git11905-802@0fd204fd-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.87 KiB) Downloaded 8 times
oscam-git11905-802@0fd204fd-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(880.73 KiB) Downloaded 6 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#474
Post by kingsman »
oscam-git11905-802
oscam-git11905-802@0fd204fd-vuduo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-mixed-upx-signed.zip
(833.31 KiB) Downloaded 4 times
oscam-git11905-802@0fd204fd-openpli40-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(888.78 KiB) Downloaded 3 times
oscam-git11905-802@0fd204fd-mips32el_generic-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(922.98 KiB) Downloaded 9 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#475
Post by kingsman »
oscam-git11905-802
oscam-git11905-802@0fd204fd-vusolo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.87 KiB) Downloaded 7 times
oscam-git11905-802@0fd204fd-vuplus4k_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.85 KiB) Downloaded 7 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#476
Post by kingsman »
oscam-git11906-802
* Use fixed-width 64-bit integer format macros
Replaced all hardcoded %lld format specifiers with the portable
inttypes.h macros PRId64 (for printing) and SCNd64 (for scanning).
This ensures correct 64-bit integer handling across 32-bit and
64-bit systems, improves cross-platform compatibility, and avoids
potential issues with long long size differences on various compilers
or architectures..
oscam-git11906-802@a93e1a0c-Linux-x86_64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-signed.zip
(864.69 KiB) Downloaded 8 times
oscam-git11906-802@a93e1a0c-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.7 KiB) Downloaded 10 times
oscam-git11906-802@a93e1a0c-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(881.05 KiB) Downloaded 7 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#477
Post by kingsman »
oscam-git11906-802
oscam-git11906-802@a93e1a0c-vuduo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-mixed-upx-signed.zip
(833.13 KiB) Downloaded 5 times
oscam-git11906-802@a93e1a0c-openpli40-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(888.78 KiB) Downloaded 6 times
oscam-git11906-802@a93e1a0c-mips32el_generic-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(922.97 KiB) Downloaded 11 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#478
Post by kingsman »
oscam-git11906-802
oscam-git11906-802@a93e1a0c-vusolo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.77 KiB) Downloaded 8 times
oscam-git11906-802@a93e1a0c-vuplus4k_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(831.78 KiB) Downloaded 10 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#479
Post by kingsman »
oscam-git11907-802
dvbapi: add support for more net send clients
* connections established with client_proto_version = 3 and extended_cw_api >= 1 can now also process CW_ALGO_CSA_ALT independently
* proper handling of dvbapi_ioctl commands in this case
* fix rerouting of msgid back to client
* support each videoguard caid
* make sure ecm.info is created
oscam-git11907-802@f0be715b-Linux-x86_64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-signed.zip
(864.5 KiB) Downloaded 3 times
oscam-git11907-802@f0be715b-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(832.01 KiB) Downloaded 5 times
oscam-git11907-802@f0be715b-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(880.63 KiB) Downloaded 6 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
#480
Post by kingsman »
oscam-git11907-802
oscam-git11907-802@f0be715b-vuduo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-mixed-upx-signed.zip
(833.31 KiB) Downloaded 8 times
oscam-git11907-802@f0be715b-openpli40-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(888.22 KiB) Downloaded 5 times
oscam-git11907-802@f0be715b-mips32el_generic-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
(922.49 KiB) Downloaded 8 times
VU+ duo4K
Multi R84
Multi R84 brutus z
