DM920 Python3 OpenPLi home build..
General discussions, images, information, tutorials, picons, skins, plugins, settings, software and tools for receivers
Been thanked: 2735 times
Re: DM920 Python3 OpenPLi home build..
#41
dm920 - Python 3.13.0 - openpli-develop-homebuild ! 20241130
- Python 3.13.0, Glibc 2.40, GCC 14.2, OpenSSL 3.4.0
- ServiceApp, FFmpeg 7.1, GStreamer 1.24.9
- Ciplus, OScamstatus, OScam
- OpenWebif, EPG-Import, File Commander, ...
- blindscan, cablescan, fastscan
- feed dm920/drivers/settings/picons/skins/plugins
Commits>>>>https://github.com/OpenPLi/enigma2/commits/develop/
- Update de.po
- pixmap-help-patch
- Use rc_model instead of SystemInfo to retreive remote default model
- Add yellow circle icon for the new Helpscreen
- Resolve navigation issues on the new Help screen
- Adjust HELP functionality to OpenVix
openpli-py3.13-dm920-20241130-homebuild
https://www.mediafire.com/file/4c1qq5wc ... ar.gz/file
#42
For those who use Streamlink
Screenshots streams in 2 Streamlink Bouquets
- Install streamlink-bouquets, restart box.
- Two Streamlink bouquets are placed on top of channellist.
- Move them to the place you want
#43
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20241214
- Python 3.13.1, Glibc 2.40, GCC 14.2, OpenSSL 3.4.0
- ServiceApp, FFmpeg 7.1, GStreamer 1.24.10
update:
- Python 3.13.0 --> 3.13.1
- GStreamer 1.24.9 --> 1.24.10
- enigma2-develop-20241213
note:
Openpli has changed the startwizard configuration buttons. Some actions use the blue button to save your box/tuner/configuration during this wizard.
openpli-py3.13-dm920-20241214.tar.gz
https://ddownload.com/9dynfdsw8jlc/open ... 214.tar.gz
#44
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20241215
- enigma2-develop-20241215
openpli-py3.13-dm920-20241215.tar.gz/file
https://www.mediafire.com/file/dn97qtpp ... ar.gz/file
#45
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20241219
update
enigma2-develop-20241219
- ServiceDVB - fix for subtitle track
- Update startwizard.xml file to the latest situations
- fix importing a resumepoints.pkl file created in Python2
- Translation 20241218
- MediaPlayer - clear playlist via buttons with confirmation only
- MediaPlayer - use VirtualKeyBoard instead InputBox
- Change Compress to Collapse in FlashImage and PluginBrowser
- Streamline some code for PluginDownloadBrowser
- Make PluginDownloadBrowser more logical
- Make the contexts from keymap.xml translatable.
- Correctly order groups/descriptions in HelpMenuList
- YouTube 1236
- OSCam 11863
Download>>openpli-py3.13-dm920-20241219.tar.gz/file
https://www.mediafire.com/file/dmtfh9x9 ... ar.gz/file
#46
Python 3.13 image
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20241222
https://ddownload.com/qoexqlla53zz/open ... 222.tar.gz
(install py3.12 image for some (closed source) plugins that don't work yet on py 3.13 image)
Python 3.12 image
dm920 - Python 3.12.8 - openpli-develop-homebuild ! 20241222
https://ddownload.com/eejth8dxjdxp/open ... 222.tar.gz
#47
dm920 - openpli-develop-homebuild ! 20241227
- Glibc 2.40, GCC 14.2, OpenSSL 3.4.0
- Ciplus, OScamstatus, OScam-emu 11863
update enigma2-develop-20241227
- Add Help screen to channelselections
- update de.po, cs.po
- SimpleChannelSelection - added epg button for select channel too
Python 3.13.1 image:
7
https://ddownload.com/t4i2qakv6l8v/open ... 227.tar.gz
Python 3.12.8 image:
https://ddownload.com/vpoxirsgmuwr/open ... 227.tar.gz
#48
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20250105
- Ciplus, OScamstatus, OScam-emu 11865
openpli-py3.13-dm920-20250105.tar.gz.zip
https://ddownload.com/xcla4tg5jd5h/open ... tar.gz.zip
#49
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20250114
- ServiceApp, FFmpeg 7.1, GStreamer 1.24.11
- Ciplus, OScamstatus, OScam-emu 11866
update:
- enigma2-develop-20250112
- exteplayer3 - IPTV_MAX_FILE_PATH 3096 (increased from 1024)
- YouTube 1265 (Exteplayer works)
- OSCam-emu 11866
- GStreamer 1.24.10 --> GStreamer 1.24.11
openpli-py3.13-dm920-20250114.tar.gz/file
https://www.mediafire.com/file/qeqpm42l ... ar.gz/file
#50
dm920 - Python 3.13.1 - openpli-develop-homebuild ! 20250127
update enigma2-develop-2024-01-27
- Fixed movieSelected
- add External subtitles
- update ru.po & zh_CN.po
- [Fixed] Wrong subtitle track numbers
- Resolve issue with changes in Selection window in ScanSetup
- In SatConfig use on_change for ConfigListScreen
- [skin] improvize callbacks function & global variables
- [networkwizard.xml] whitespace cleanup
- [servicemp3] add header, fix getSubtitleList
- [exteplayer3] Increase buffer size to accommodate long URLs
openpli-py3.13-dm920-20250127.tar.gz/file
https://www.mediafire.com/file/gmna9zmt ... ar.gz/file
