BouquetMakerXtream (BMX) - v1.51
Fixed a potential crash if iptv server doesn't respond.
[Plugin] Bouquet Maker Xtream - IPTV Bouquet Maker (new 2023)
Re: [Plugin] Bouquet Maker Xtream - IPTV Bouquet Maker (new 2023)
- enigma2-plugin-extensions-bouquetmakerxtream_1.51_20250418_all.deb
- (1.13 MiB) Downloaded 47 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.51.20250418_all.ipk
- (1.4 MiB) Downloaded 61 times
BouquetMakerXtream (BMX) - v1.52
Added in EPG offset option in playlist settings.
For those images that support it, (not all do), this will add an offset in epg import source files.
i.e you can move your epg schedule back or forward if the programmes are out of sync with the actual local tv schedule.
Your playlist info page will tell you your providers server offset. In most cases this is also your epg offset. But I have made it a manual offset that is set in settings.
- enigma2-plugin-extensions-bouquetmakerxtream_1.52_20250430_all.deb
- (1.13 MiB) Downloaded 64 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.52.20250430_all.ipk
BouquetMakerXtream (BMX) - v1.53
Fixed a potential crash in saving settings
- enigma2-plugin-extensions-bouquetmakerxtream_1.53_20250517_all.deb
- (1.13 MiB) Downloaded 66 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.53.20250517_all.ipk
- (1.4 MiB) Downloaded 71 times
BouquetMakerXtream (BMX) - v1.54
Fixed series logic. It was totally broke since 1.47
(and apologies for taking so long... every time I went to test your line - it was active and being used)
- enigma2-plugin-extensions-bouquetmakerxtream_1.54_20250520_all.deb
- (1.13 MiB) Downloaded 69 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.54.20250520_all.ipk
- (1.4 MiB) Downloaded 96 times
