FileZilla Latest Version/Update
- Been thanked: 2735 times
Re: FileZilla Latest Version/Update
FileZilla Server v1.9.3 Released
New Update:17.10.2024
Bugfixes and minor changes:
- Fixed a regression causing the automatic renewal of the Let's Encrypt® certificates to not work properly..
- UI: fixed regression causing the Administration Interface port of the last successful connection to not be properly restored..
- UI: fixed a bug where the TLS key appeared to be lost in the interface if certificate generation failed, even though the key was still retained on the server..
https://filezilla-project.org/download. ... ype=server
FileZilla Client v3.68.0-rc1 Released
New Update:18.10.2024
New features:
Added option to always refresh remote directory listings when starting a recursive operation..
- Changing logfile settings no longer requires a restart of FileZilla..
- Fixed a display issue with special characters in usernames..
- MSW: Fixed local file list not updating after renaming or deleting items..
- SFTP: Update interval of transfer progress during uploads should now be more consistent on very slow connections..
- Updated to libfilezilla 0.49.0..
Download
https://filezilla-project.org/download. ... l=1&beta=1
New features:
Download
FileZilla Client 3.68.0 released
Please select the file appropriate for your platform under download.
The latest stable version of FileZilla Client is 3.68.1
Please select the file appropriate for your platform below.
Linux (64bit x86)
FileZilla_3.68.1_x86_64-linux-gnu.tar.xz
Built for Debian 10.0 (Buster) 64bit edition. It is highly recommended to use the package management system of your distribution or to manually compile FileZilla if you are running a different flavour of Linux.
Windows (64bit x86)
FileZilla_3.68.1_win64-setup.exe (recommended)
FileZilla_3.68.1_win64.zip
Linux (64bit x86)
Windows (64bit x86)
FileZilla Server v1.9.4 Released
New Update:11.11.2024
- Fixed a regression causing the setting 'do not require authentication' to get lost when restarting the server. Note: To see the effect of this fix, administrators must manually reapply the 'do not require authentication' setting for affected users. After this adjustment, the setting will persist as expected..
- MSW: Added NETWORK_SERVICE as a allowed user for the config dir ownership..
Download
Download
The latest stable version of FileZilla Client is 3.69.0
Download
Download
https://filezilla-project.org/download.php?show_all=1- Hannibal_Lecter
FileZilla Client 3.69.1 released
Fixed initial loading of file extensions for the Auto transfer type
FileZilla - The free FTP solution
- 281 Views
- 3937 Views
- 88 Replies
- 8194 Views
- 402 Views
- 5155 Views
