Latest Version of OScam
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
Re: Latest Version of OScam
oscam-git11816-802
- oscam-git11816-802@8605641b-vusolo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.91 KiB) Downloaded 37 times
- oscam-git11816-802@8605641b-vuplus4k_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.91 KiB) Downloaded 25 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
build Levi45
New Update:18.08.2024
OsCam Icam Patch 11816 With emu r802 ipk/deb for all E2/Sh4 boxes and images..
- enigma2-plugin-softcams-oscam-emu-levi45_11816-802_ipk_all.rar
- (3.07 MiB) Downloaded 34 times
- enigma2-plugin-softcams-oscam-emu-levi45_11816-802_deb_all.rar
- (1.97 MiB) Downloaded 26 times
- kingsman
oscam-git11817-802
signing: exclude oscam-signing.* from cmake build if WITH_SIGNING is disabled
- oscam-git11817-802@13be65d9-Linux-x86_64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed.zip
- (850.48 KiB) Downloaded 25 times
- oscam-git11817-802@13be65d9-dream_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.99 KiB) Downloaded 28 times
- oscam-git11817-802@13be65d9-dream_aarch64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (746.49 KiB) Downloaded 29 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11817-802
- oscam-git11817-802@13be65d9-vuduo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.92 KiB) Downloaded 28 times
- oscam-git11817-802@13be65d9-openpli40-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (780.96 KiB) Downloaded 27 times
- oscam-git11817-802@13be65d9-mips32el_generic-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (782.81 KiB) Downloaded 27 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11817-802
- oscam-git11817-802@13be65d9-vusolo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.93 KiB) Downloaded 29 times
- oscam-git11817-802@13be65d9-vuplus4k_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed-upx.zip
- (702.92 KiB) Downloaded 25 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11818-802
Several bugs fix
* Give back msglog when ECM is "found"
* Fix bug where some log messages were overwritten when compile with CacheEX enabled
* Fix HD04H entitlements expire date display and formatting some codes.
* Fix tag api query to order the results by version and sort descending
Several bugs fix
- oscam-git11818-802@97aca8c2-Linux-x86_64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-signed.zip
- (857.58 KiB) Downloaded 24 times
- oscam-git11818-802@97aca8c2-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.22 KiB) Downloaded 29 times
- oscam-git11818-802@97aca8c2-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (753.1 KiB) Downloaded 27 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11818-802
- oscam-git11818-802@97aca8c2-vuduo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.22 KiB) Downloaded 27 times
- oscam-git11818-802@97aca8c2-openpli40-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (788.6 KiB) Downloaded 20 times
- oscam-git11818-802@97aca8c2-mips32el_generic-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (789.04 KiB) Downloaded 22 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11818-802
- oscam-git11818-802@97aca8c2-vusolo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.19 KiB) Downloaded 27 times
- oscam-git11818-802@97aca8c2-vuplus4k_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.21 KiB) Downloaded 29 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11819-802
Fix some edge cases
- SSL: support OpenSSL installations in non standard locations (cmake)
- SSL: show OpenSSL include directory in buildlog (cmake)
- SSL: remove -Wunused-value warning for SSL_CTX_set_ecdh_auto dispayed on some systems
- SIGNING: ensure a missing signing certificate is created on first build (cmake)
- SIGNING: fix filtering oscam-signing.[c|h] when WITH_SIGNING is disabled (cmake)
- LIBDVBCSA: fix link filename (cmake)
- LIBDL: link libdl by default for Linux as it is required by some systems (cmake)
- CONFIG: Fix display of configured values
Fix some edge cases
- oscam-git11819-802@d16d1e07-Linux-x86_64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-signed.zip
- (857.84 KiB) Downloaded 27 times
- oscam-git11819-802@d16d1e07-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.29 KiB) Downloaded 23 times
- oscam-git11819-802@d16d1e07-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (753.27 KiB) Downloaded 26 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11819-802
- oscam-git11819-802@d16d1e07-vuduo4k-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (710.33 KiB) Downloaded 25 times
- oscam-git11819-802@d16d1e07-openpli40-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (788.52 KiB) Downloaded 40 times
- oscam-git11819-802@d16d1e07-mips32el_generic-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-mixed-upx-signed.zip
- (789.43 KiB) Downloaded 24 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- 867 Views
- 834 Views
- 3955 Views
- 5183 Views
- 88 Replies
- 8493 Views
