Oscam-Emu.patch
gugo111
Been thanked: 2 times
Armenia
Re: Oscam-Emu.patch
#21
Post by gugo111 »
hello friends, help me figure out the DM800HDSE receiver the OSCam is on: 1.20_svn Build: r11717 Compiler: mipsel-oe-linux emulator I can't open the biss channels help me how to open the biss channels
Has thanked: 14316 times
Been thanked: 1591 times
Re: Oscam-Emu.patch
#22
gugo111 wrote: 18 Nov 2025, 23:47 hello friends, help me figure out the DM800HDSE receiver the OSCam is on: 1.20_svn Build: r11717 Compiler: mipsel-oe-linux emulator I can't open the biss channels help me how to open the biss channels
use oscam patch
oscam emu
gugo111
Armenia
Re: Oscam-Emu.patch
#23
Post by gugo111 »
how to install Oscam-Emu.patch in the receiver help
Re: Oscam-Emu.patch
#24
as same u install oscam normel
How to Install OSCam on DM800HDSE (Enigma2)
Requirements
DM800HDSE with Enigma2 image (OpenPLi, OpenATV, Newnigma2, etc.)
SSH/Telnet access (PuTTY)
FTP access (FileZilla)
OSCam IPK file
METHOD 1 — Install OSCam Using IPK (Easiest Method)
1️⃣ Download an OSCam .ipk
Search for one of these packages (depending on your image):
enigma2-softcams-oscam.ipk
oscam-modern.ipk
oscam-stable.ipk
Make sure it matches your image architecture:
DM800HDSE = mips32el (mipsel)
2️⃣ Upload to the Box
Using FileZilla:
Upload the .ipk file to:
/tmp/
3️⃣ Install Using Telnet
Open PuTTY → enter box IP → login:
opkg install /tmp/*.ipk
If it shows dependency issues, run:
opkg update
opkg install /tmp/*.ipk --force-overwrite
4️⃣ Start OSCam
Depending on your image:
OpenPLi:
Menu → Applications → Softcam/CI → Select OSCam → Start
OpenATV:
Menu → Information → Softcam → OSCam → Start
Newnigma2:
Blue Panel → Softcams → OSCam → Start
📌 METHOD 2 — Manual OSCam Install
If IPK not working:
1️⃣ Download OSCam binary (mipsel)
Name example:
oscam-1.20-mipsel
2️⃣ Upload to:
/usr/bin/
Set permissions:
chmod 755 /usr/bin/oscam
3️⃣ Create softcam script
Place script here:
/etc/init.d/softcam.oscam
Make executable:
chmod 755 /etc/init.d/softcam.oscam
📁 OSCam Config Folder
Different images use different paths:
Try these:
/etc/tuxbox/config/oscam/
/etc/oscam/
/usr/keys/
/var/keys/
Place files:
oscam.conf
oscam.server
oscam.user
oscam.dvbapi
🌐 Access OSCam Web Interface
Default:
http://BOX-IP:8888
Login:
user: root
password: oscam
(may vary depending on build)
gugo111
Armenia
Re: Oscam-Emu.patch
#25
Post by gugo111 »
hi, can I ask you if it is possible to launch the ntv plus card in oscame? the card is linked to an official receiver. help me launch the card in oscame
Re: Oscam-Emu.patch
#26
gugo111 wrote: 20 Nov 2025, 11:26 hi, can I ask you if it is possible to launch the ntv plus card in oscame? the card is linked to an official receiver. help me launch the card in oscame
card info share plzz
caid?
ident?
cas?
sat?
box chip?
gugo111
Armenia
Re: Oscam-Emu.patch
#27
Post by gugo111 »
friends, to launch the NTVPLUS card, you need an aeskeys card linked to an official receiver, help launch the card in OSCAM caid?0500 ident?0500:050A00 cas?Viaccess sat?EUTELSAT 36C,D, 36° in.d box chip?
0x6EDC4EA8 help me give a confucius
gugo111
Armenia
Re: Oscam-Emu.patch
#28
Post by gugo111 »
I need aeskeys to help me
gugo111
Armenia
Re: Oscam-Emu.patch
#29
Post by gugo111 »
and even more, how can the Stream Relay be installed in dm800HDSE so that it looks on the computer, help with a config how to install and create an IPTV sheet
gugo111
Armenia
Re: Oscam-Emu.patch
#30
Post by gugo111 »
hello friends, there is an ntv plusrussia card, help launch the card in OSCam dm800HDse receiver caid 0500 ident 0500:050A00 encoding Viaccess help launch the card
Return to “Oscam”
