oDreamy_FHD_Mod
Re: oDreamy_FHD_Mod
#21
XDREAMY v 4.3.1
"Experience Enigma2 skin like never before with XDREAMY"
"XDREAMY skin is a new vision, created by Inspiron. Users can fully customize their interface, and change layout, colors, fonts, and screens to suit their preferences. Drawing inspiration from Dreamy and oDreamy skins, XDREAMY incorporates cutting-edge rendering technology, including the efficient PosterX component recoded by Lululla."
Supported Images
Alliance Based Images: (Egami 10.x, OpenATV 6.x, OpenATV 7.x,
OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH)
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF and NSS )
Fix the Installation Script to set the image logo automatically.
Download
enigma2-plugin-skins-xDreamy_4.3.1_all.ipk
https://ddownload.com/4fbkwalqh0c8/enig ... .1_all.ipk
Re: oDreamy_FHD_Mod
#22
XDREAMY v 4.4.0
enigma2-plugin-skins-xDreamy_4.4.0_all.ipk
https://ddownload.com/gxiuj8yldtz7/enig ... .0_all.ipk
Re: oDreamy_FHD_Mod
#23
XDREAMY v 4.5.0
Option to change the Menu Font Color
Option to change the channels Name Color
Replace some renderers with older ones for better performance
Tweaking and optimizing skin files (now better performance and faster response).
Handel a lot of users' requests
Virtual Keyboard (working on some images, not finished yet).
Code:
https://raw.githubusercontent.com/Inspr ... staller.sh -O - | /bin/sh
Features:
Dedicated plugin for skin customization.
Over 10 built-in Bootlogos.
Over 5 additional skin styles can be applied to change your skin layout.
Over 15 different color styles can be applied to change your skin GUI
Over 15 different font styles can be applied to change your skin font style
Over 6 different Keys styles can be applied to change your skin font style
Over 11 Channels list screens with and without posters.
Direct Weather Plugin Install and set locations.
Direct API set for TMDB & OMDB websites.
Many InfoBar and Second InfoBar with and without posters
Many Event View screen styles with and without posters
Powerful and reliable PosterX renderer (Recoded by Mr.Lululla)
Special Thanks:
Lululla, for his close skin revision, debugging, and code tracking, as well as fixing, updating, and improving.
giopet for his testing efforts and issues reporting.
oktus for sharing new design ideas.
enigma2-plugin-skins-xDreamy_4.5.0_all
https://www.mediafire.com/file/mmfw27lm ... l.ipk/file
Re: oDreamy_FHD_Mod
#24
XDREAMY v 4.6.0
Supported Images
OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH).
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF, NonSoloSat, OpenTR and Satlodge )
We have new Recoding for all renderers for better performance, accurate results, and fast response. Now, Ratings, Stars, and Posters are downloading much better—special thanks to Lululla for his efforts.
telnet code:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Inspr ... staller.sh -O - | /bin/sh
enigma2-plugin-skins-xDreamy_4.6.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=6744
Re: oDreamy_FHD_Mod
#25
XDREAMY v 4.7.0
Supported Images
Alliance Based Images: (Egami 10.x, OpenATV 6.x, OpenATV 7.x, OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH).
Fix the channel list error not being visible after the initial installation with ipk file.
More tweaking and optimizing of skin files is needed (now, better performance and faster response).
XDREAMY PLUGIN: Refresh the interface of XDREAMY Plugin.
XDREAMY PLUGIN: Add an Information Message, including the list of supported images (Press info while opening the plugin).
XDREAMY PLUGIN: Add Skin debugging tools to show skin errors for users (Active only when you have LinuxSat Panel on the system)
Telnet Code
(Direct Install)
Code:
Special Thanks:
Features:
Please note:
I am not a professional skinner or developer, or anything related to sat, enigma...etc., but I like to make some customization to my box skin so that you can enjoy it on your responsibility.
Preview images in the xDreamy plugin are not finished yet.
Some skin features are not properly displayed with the OpenPLi image (due to the old Python version). Moreover, there is no box image available in the OpenPLI image, so if you want to display your box image on the skin, you have to manually copy your box image from the path (usr/share/enigma2) to the skin folder and rename it (boximage.png).
enigma2-plugin-skins-xDreamy_4.7.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=6898
Re: oDreamy_FHD_Mod
#26
XDREAMY v 4.8.0
Supported Images
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF, NonSoloSat, OpenTR, Cobra and Satlodge )
More tweaking and optimizing of skin files is needed (now, better performance and faster response) Your new feedback is much appreciated
XDREAMY PLUGIN: I added the skin version number to the title to make it more visible.
Finally, the virtual keyboard for pure2 image should be fixed and improved.
Cam Data displayed in Cam Manger (OpenATV), you can change the used Converter from the skin plugin.
Add new screen History Zap Selector.
Remove force restart (killall -9 enigma2) from postinst file (some people believe it is too aggressive),
Handel a lot of users' requests.
Download IPK: https://www.mediafire.com/file/fq02vvbp ... l.ipk/file
Telnet Code:
Special Thanks:
Features:
Please note:
enigma2-plugin-skins-xDreamy_4.8.0_all.ipk
https://www.satworld-forum.com/download ... hp?id=7068
Return to “Skins”
