FileZilla Latest Version/Update
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Been thanked: 1692 times
Re: FileZilla Latest Version/Update
#21
Post by sugar »
FileZilla Client v3.66.5 Released
    New Update:07.02.2024
    Fixed vulnerabilities:
    -Official binaries are now built againt GnuTLS 3.8.3..
    Bugfixes and minor changes:
    -Updated to libfilezilla 0.46.0..
    -MSW: Fixed tab navigation over message log..
    Display Less
Download FileZilla Client
https://filezilla-project.org/download.php?show_all=1
Has thanked: 11 times
Been thanked: 1944 times
#22
FileZilla Client v3.67.0 Released
New Update:16.04.2024
-SFTP: Fixed PuTTY ECDSA NIST P-521 private key recovery vulnerability (CVE-2024-31497). If you use NIST P-521 keys to connect to SSH/SFTP servers, you should regenerate them and revoke the previous ones.
-Official binaries are now built against GnuTLS 3.8.4
-Updated to libfilezilla 0.47.0
The information and uploads I have provided are for testing purposes only.
Pay-TV reception without a valid subscription is illegal and punishable by law.
sugar
Global Moderator
Global Moderator
#23
Post by sugar »
FileZilla Server v1.8.2 Released
 New Update:26.04.2024
    FileZilla Server now requires that the configuration directory is owned either by the operating system user account the server runs under, or a more privileged user (SYSTEM, Amdministrators, TrustedInstaller on Windows, root elsewhere)
    MSW: Mount points are now case-insensitive so that restrictions on sub mounts cannot be bypassed by a change of character case..
    Fixed a potential deadlock during transfers..
    FTP: Fixed potential crash if the session gets closed..
Download FileZilla Server v1.8.2
https://filezilla-project.org/download. ... ype=server
sugar
Global Moderator
Global Moderator
#24
Post by sugar »
FileZilla Client v3.67.1-rc1 Released
    New Update:27.06.2024
    - Fixed an issue migrating old queue files if several older versions have been skipped..
    - Updated to libfilezilla 0.48.0..
https://filezilla-project.org/download. ... l=1&beta=1
#25
FileZilla Client v3.67.1 Released
New Update:10.07.2024
- MSW: Fixed an issue with confirmation dialogs for file deletion not being modal..
- Updated to libfilezilla 0.48.1..
#26
FileZilla Server v1.9.0-rc1 Released
New Update:08.08.2024
New features:
- Private keys used for TLS can now be stored on a PKCS#11-compatible token device; the UI has been updated accordingly.
- UI: added button to retrieve the current FileZilla Server's public IP address, useful to configure the PASV mode.
- UI: added an FTP connection test, that can be reached directly from the Server menu item or executed at the end of the FTP Network Configuration Wizard.
- Made default values more secure, among which: require TLS on new FTP listeners, require a password for new users and warn if the administration password doesn't meet more stringent security requirements.
- Fixed bug causing the most recent log file, rather than the oldest, to be deleted upon rotation, when using dates as suffixes.
- MSW: fixed regression causing socket listener conflicts due to recent libfilezilla changes.
- Added WebUI: an HTTP server providing a REST API and a web app for seamless web access to stored files. WebUI is not included in the default build and must be enabled with the --enable-webui parameter during compilation. This feature is experimental; feedback and bug reports are welcome.
- UI: the certificate fingerprint verification dialog is now sized to display the full fingerprint at once.
- UI: fixed bug causing the focus to be lost during user editing.
- UI: fixed bug causing the tray icon to display unexpectedly in certain cases.
- UI: improved error handling in case of server disconnection.
- UI: improved handling of Settings window size on ultra wide screens.
- FTP: the MKD command now returns an error if the directory already exists.
- FTP: Improved login timeout handling to exclude internal server processing time.
- Fixed heap corruption in the Administrator Interface.
- Fixed regression in the path handling routines.
#27
FileZilla Server v1.9.0 Released
New Update:05.09.2024
- MSW: Warn if installing the server outside of Program Files due to custom directories having too lax permissions..
- Fixed a race condition resulting in stalled connections..
- *nix: Fixed a potential crash if SIGINT is sent to the server while it is shutting down..
- Fixes to the update check mechanism..
- Fixed a regression in the converter for old 0.9.x configurations dealing with placeholders in native paths.
#28
FileZilla Server v1.9.1 Released
New Update:09.09.2024
- Fixed a regression introduced in 1.9.0, the "public IP or hostname" field on the passive mode page was not restored when opening the settings dialog
sugar
Global Moderator
Global Moderator
#29
Post by sugar »
Quote
- Fixed a regression introduced in 1.9.0, the "public IP or hostname" field on the passive mode page was not restored when opening the settings dialog..
#30
FileZilla Server v1.9.2 Released
New Update:30.09.2024
- Fixed an issue with the update mechanism..
