Latest Version of OScam
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
Re: Latest Version of OScam
oscam-git11810-802
* Update README.config
- oscam-git11810-802@2d0e3aca-Linux-x86_64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed.zip
- (850.46 KiB) Downloaded 31 times
- oscam-git11810-802@2d0e3aca-dream_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.83 KiB) Downloaded 47 times
- oscam-git11810-802@2d0e3aca-dream_aarch64-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (746.31 KiB) Downloaded 34 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11810-802
- oscam-git11810-802@2d0e3aca-vuduo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.82 KiB) Downloaded 36 times
- oscam-git11810-802@2d0e3aca-openpli40-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (780.97 KiB) Downloaded 35 times
- oscam-git11810-802@2d0e3aca-mips32el_generic-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (782.85 KiB) Downloaded 37 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11810-802
- oscam-git11810-802@2d0e3aca-vusolo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.83 KiB) Downloaded 37 times
- oscam-git11810-802@2d0e3aca-vuplus4k_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.8 KiB) Downloaded 38 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11811-802
Introduce upx compression support
* support for upx compression of oscam binary after build (new option `USE_COMPRESS` default off)
* support for upx compression level adjustment (new option `COMP_LEVEL` default --best)
* buildlog shows upx version, compression level, build date
* additional entry for build date in oscam.version file
* gitlab pipeline installs upx binary automatically and uses upx compression for native make/cmake test builds
- oscam-git11811-802@c04157c1-Linux-x86_64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed.zip
- (850.57 KiB) Downloaded 47 times
- oscam-git11811-802@c04157c1-dream_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.84 KiB) Downloaded 31 times
- oscam-git11811-802@c04157c1-dream_aarch64-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (746.45 KiB) Downloaded 35 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11811-802
- oscam-git11811-802@c04157c1-vuduo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.87 KiB) Downloaded 39 times
- oscam-git11811-802@c04157c1-openpli40-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (781.05 KiB) Downloaded 35 times
- oscam-git11811-802@c04157c1-mips32el_generic-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (782.84 KiB) Downloaded 37 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11811-802
- oscam-git11811-802@c04157c1-vusolo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.88 KiB) Downloaded 33 times
- oscam-git11811-802@c04157c1-vuplus4k_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.87 KiB) Downloaded 30 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11812-802
Fix IPv4 fallback
* automatic fallback to IPv4 if the reader have an AAAA and an A record and the connect via IPv6 failed
* automatic fallback to IPv4 name resolution if a user connects (with a set 'hostname' parameter) and have an AAAA and an A record and IPv6 does not match
* new reader option ipv4force = {0|1} (always use IPv4) to force IPv4 usage
* automatic fallback to IPv4 on server-listener
Fix IPv4 fallback
- oscam-git11812-802@6e874d2d-Linux-x86_64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed.zip
- (850.54 KiB) Downloaded 52 times
- oscam-git11812-802@6e874d2d-dream_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.81 KiB) Downloaded 34 times
- oscam-git11812-802@6e874d2d-dream_aarch64-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (746.47 KiB) Downloaded 34 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11812-802
- oscam-git11812-802@6e874d2d-vuduo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.8 KiB) Downloaded 32 times
- oscam-git11812-802@6e874d2d-openpli40-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (780.96 KiB) Downloaded 47 times
- oscam-git11812-802@6e874d2d-mips32el_generic-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (782.72 KiB) Downloaded 35 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11812-802
- oscam-git11812-802@6e874d2d-vusolo4k-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.81 KiB) Downloaded 33 times
- oscam-git11812-802@6e874d2d-vuplus4k_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.82 KiB) Downloaded 44 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
oscam-git11813-802
Show compression information
* additional entry for compression tool, version and level in the oscam.version file
* generation of the entry depends on USE_COMPRESS parameter
* add missing COMP_LEVEL variable helptext in Makefile
* minor whitespace fix
- oscam-git11813-802@1ecc214e-Linux-x86_64-webif-dvbapi-libusb-libdvbcsa-emu-icam-mixed.zip
- (850.47 KiB) Downloaded 48 times
- oscam-git11813-802@1ecc214e-dream_arm-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (702.97 KiB) Downloaded 32 times
- oscam-git11813-802@1ecc214e-dream_aarch64-webif-dvbapi-libusb-libdvbcsa-emu-icam-upx-mixed.zip
- (746.53 KiB) Downloaded 35 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
