oDreamy_FHD_Mod
- Been thanked: 2735 times
Re: oDreamy_FHD_Mod
XDREAMY v 3.4
Supported Images
Egami 10.x, OpenATV 6.x, OpenATV 7.x,
OpenSpa 8.x, PurE2 6.x, PurE2 7.x & Alliance Based Images
Add EventView Full Screen Poster.
Add E2iPlayer settings Screens
Add KeyAdder Plugin Screens
Add ScreenGrabber Plugin Screens
Add IPTOSAT Plugin Screens
Add Subsupport Plugin Settings Screen.
Add BundesligaPermanentClock Plugin Screens
Add Transmission Plugin Settings Screen.
Remove useless font files (ipk size reduced by 3 MB)
Remove useless files and screens
Minor fixes and layout improvements.
Features:
Detected plugin for skin customization
Over 5 additional skin styles can be applied to change your skin layout.
Over 15 different color styles can be applied to change your skin GUI
Over 15 different font styles can be applied to change your skin font style
Over 6 different Keys styles can be applied to change your skin font style
Many Channels list screens with and without posters
Many InfoBar and Second InfoBar with and without posters
Many Event View screen styles with and without posters
Powerful and reliable PosterX renderer (Recoded by Mr.Lululla)
https://www.mediafire.com/file/p23h0lk6 ... l.ipk/file
Supported Images
Features:
Re: oDreamy_FHD_Mod
XDREAMY SKIN V 3.6
Soooon.....
1. Style 6. Transparent
2. Transmission Plugin full screens.
3. Weather Plugin you will display weather information based on your favorite weather Plugin .
4. Bitrate information from Bitrate plugin or bitrate renderer.
5. Fixes and improvements. Thanks Lululla for continuous testing and support.
https://fastupload.io/a28e4b92a691940d
Soooon.....
Re: oDreamy_FHD_Mod
XDREAMY v 3.7 10.10.2024
Supported Images
OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid & Alliance Based Images
OpenPLi, OpenVIX (Experimental)
Support of OpenVIX image (100 %)
Support of OpenPLi image (100 %) Some skin features are not displayed properly due to the old Python version
Support of OpenDroid image (95%)
11 New Channel List templates (screen preview in XDREAMY PLUGIN not ready yet)
Fix the GUI screen in OpenATV, which now shows a skin preview.
Modify the installation script to match the newly supported images.
Supported Images
- enigma2-plugin-skins-xDreamy_3.7.0_all.ipk
- (20.94 MiB) Downloaded 78 times
Re: oDreamy_FHD_Mod
XDREAMY v 3.7.1
(Online Update)
13.10.2024
Supported Images
Added more screens for Opendroid image, OPD team screens & OPD Multiboot.
Fix some fonts sizes.
Update some components.
Reduce skin size to 16 MB.
General fixes and improvements
(Online Update)
13.10.2024
Supported Images
Re: oDreamy_FHD_Mod
XDREAMY v 3.8.0
17.10.2024
"Experience Enigma2 skin like never before with XDREAMY"
"XDREAMY skin is a new vision, created by Inspiron. Users can fully customize their interface, and change layout, colors, fonts, and screens to suit their preferences. Drawing inspiration from Dreamy and oDreamy skins, XDREAMY incorporates cutting-edge rendering technology, including the efficient PosterX component recoded by Lululla."
Supported Images
(OpenPLi, OpenVIX)
IPK size reduced to 16 MB.
Added more screens for OpenDroid, Pure2, OpenViX & OpenPLi
Added screens for Levi45 MultiCamManager ( levi45)
Added screens for EPGRefresh Plugin
Fix Channels screen names (CHL08 name was not correct, all should work now)
Fix the Software Update screen in the pure2 image (Thanks for your feedback)
Finally, SNR & AGC numbers are displayed properly everywhere (it works with % only).
Add Biss to infobar
All MSN Weather data work on infobar and secondinfobar.
Many fixes and layout improvements.
Features:
Dedicated plugin for skin customization
Over 11 Channels list screens with and without posters
Please note:
I am not a professional skinner or developer, or anything related to sat, enigma...etc., but I like to make some customization to my box skin so that you can enjoy it on your responsibility.
Preview images in the xDreamy plugin are not finished yet.
Some skin features are not properly displayed with the OpenPLi image (due to the old Python version). Moreover, there is no box image available in the OpenPLI image, so if you want to display your box image on the skin, you have to manually copy your box image from the path (usr/share/enigma2) to the skin folder and rename it (boximage.png).
17.10.2024
Supported Images
(OpenPLi, OpenVIX)
Add Biss to infobar
Features:
Please note:
- enigma2-plugin-skins-xDreamy_3.8.0_all.ipk
- (15.96 MiB) Downloaded 56 times
Re: oDreamy_FHD_Mod
XDREAMY v 3.9.0
Supported Images
(OpenPLi, OpenVIX)
(OpenBH)
Support OpenBlackHole Image (New).
Update XDREAMY Plugin (Thanks Lululla)
Handel some requests
Features:
Please note:
Supported Images
(OpenPLi, OpenVIX)
(OpenBH)
Features:
Please note:
- enigma2-plugin-skins-xDreamy_3.9.0_all.ipk
- (15.45 MiB) Downloaded 66 times
Re: oDreamy_FHD_Mod
XDREAMY v 3.9.1
"XDREAMY skin is a new vision, created by Inspiron. Users can fully customize their interface, and change layout, colors, fonts, and screens to suit their preferences. Drawing inspiration from Dreamy a oDreamy skins, XDREAMY incorporates cutting-edge rendering technology, including the efficient component recoded by Lululla
Supported Images
(OpenPLi, OpenVIX)
(OpenBH)
Correct Templates file for Openpli image menu.
Fix SNR, AGC & event progress bars in openpli.
Clean up of some useless screens.
Minor Fixs
XDREAMY v 3.9.1
Supported Images:
(OpenPLi, OpenVIX)
OpenBH)
Minor Fixs
Update available online through XDREAMY plugin and download link below
enigma2-plugin-skins-xDreamy_3.9.1_all.ipk/file
https://www.mediafire.com/file/m73crj93 ... l.ipk/file
Supported Images
(OpenPLi, OpenVIX)
(OpenBH)
Minor Fixs
XDREAMY v 3.9.1
Supported Images:
(OpenPLi, OpenVIX)
OpenBH)
Minor Fixs
Re: oDreamy_FHD_Mod
XDREAMY v 4.3.0
Supported Images:
Alliance Based Images: (Egami 10.x, OpenATV 6.x, OpenATV 7.x,
OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH)
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF and NSS )
Plugin Browser Grid Screen (4 new Screens)
EventView Screen (5 Refreshed Screens with Parental Rating and Stars)
Channels List Screen Added 15 new screens. (with Parental Rating and Stars in different colors (NBG)
Better Posters identify, download, and Display over quick zapping (Thanks For Lululla).
Recoding for Parental and Stars Renderers for better responses and better name search (Thanks for Lululla)
Tweaking and optimizing skin files (now better performance and faster response).
Handel a lot of users' requests
Virtual Keyboard (working on some images, not finished yet).
thx @Mahmoud Hussein
Telnet:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Inspr ... staller.sh -O - | /bin/sh
Download
https://www.mediafire.com/file/5ld96zn4 ... l.ipk/file
Supported Images:
Telnet:
Download
