OScam/EMU arm32 (DM900/920/all-VU4K, armv7)
Been thanked: 2735 times
OScam/EMU arm32 / mips / aach64 (DM900/920/all-VU4K, armv7)
#11
Oscam für DM9XXX / VU+ 4k mit u. ohne ipv6 Support ibdvbcsa integriert r11778.ipk
enigma2-plugin-softcams-oscam-icam_r11778_ipk_all.zip
(2.61 MiB) Downloaded 50 times
#12
Oscam für DM9XXX / VU+ 4k mit u. ohne ipv6 Support ibdvbcsa integriert binaries only
oscam-git11779@57e8a3e6-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed.zip
oscam-git11779@57e8a3e6-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-neon-upx-mixed.zip
oscam-git11779@57e8a3e6-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-dream_aarch64-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-mipsel-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-mipsoe20-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-mipsoe20-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed.zip
oscam-git11779@57e8a3e6-vuplus4k_armv7a-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed.zip
thx uf2k
(660.48 KiB) Downloaded 59 times
(576.7 KiB) Downloaded 41 times
(658.47 KiB) Downloaded 74 times
(633.18 KiB) Downloaded 132 times
(628.01 KiB) Downloaded 61 times
(584.35 KiB) Downloaded 42 times
(584.4 KiB) Downloaded 85 times
(583.44 KiB) Downloaded 36 times
(585.33 KiB) Downloaded 63 times
OScam/EMU arm32 / mips / aach64(DM900/920/all-VU4K, armv7)
#13
Oscam für DM9XXX / VU+ 4k mit u. arm / mips / aach64 Support u. ibdvbcsa integriert
IPK r11779 nur für VTI Image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv_r11779.ipk
enigma2-plugin-softcams-oscam-icam-vti_r11779.ipk
thx uf2k
enigma2-plugin-softcams-oscam-icam-vti_r11779_ipk_all.zip
(1.77 MiB) Downloaded 39 times
enigma2-plugin-softcams-oscam-icam-openatv_r11779_ipk_all.zip
(2.61 MiB) Downloaded 45 times
#14
Bevor ihr diese ipk verwendet, achtet auf dem Datei Namen der ipk, denn vti nur mit VTI Image und openatv nur mit OpenATV Image!!!!
IPK r11780 nur für OpenATV Image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv_r11780.ipk
IPK r11780 nur für VTI Image: arm / mips
enigma2-plugin-softcams-oscam-icam-vti_r11780.ipk
thx uf2k
enigma2-plugin-softcams-oscam-icam-vti_r11780_all_ipk.zip
(1.23 MiB) Downloaded 96 times
enigma2-plugin-softcams-oscam-icam-openatv_r11780_all_ipk.zip
(1.85 MiB) Downloaded 107 times
#15
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-neon-upx-mixed
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed
oscam-git11780@77374920-dream_aarch64-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed
oscam-git11780@77374920-mipsel-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed
oscam-git11780@77374920-mipsoe20-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed
oscam-git11780@77374920-mipsoe20-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed
oscam-git11780@77374920-vuplus4k_armv7a-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed
thx uf2k
oscam-git11780@77374920-vuplus4k_armv7a-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed.zip
(577.5 KiB) Downloaded 56 times
oscam-git11780@77374920-mipsoe20-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed.zip
(660.39 KiB) Downloaded 74 times
oscam-git11780@77374920-mipsoe20-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
(658.84 KiB) Downloaded 84 times
oscam-git11780@77374920-mipsel-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
(633.26 KiB) Downloaded 85 times
oscam-git11780@77374920-dream_aarch64-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
(629.06 KiB) Downloaded 50 times
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-upx-mixed.zip
(584.89 KiB) Downloaded 52 times
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-ipv6-icam-neon-upx-mixed.zip
(584.59 KiB) Downloaded 55 times
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-upx-mixed.zip
(583.25 KiB) Downloaded 48 times
oscam-git11780@77374920-arm_dream-webif-dvbapi-ssl-libdvbcsa-icam-neon-upx-mixed.zip
(583.16 KiB) Downloaded 119 times
#16
enigma2-plugin-softcams-oscam-icam-openatv_r11781.ipk
enigma2-plugin-softcams-oscam-icam-vti_r11781.ipk
Wenn man die cam wieder entfernen will kann man das über telnet oder ssh machen
opkg remove enigma2-plugin-softcams-oscam-icam-openatv
opkg remove enigma2-plugin-softcams-oscam-icam-vti
thx uf2k
enigma2-plugin-softcams-oscam-icam-vti_r11781_all.ipk.zip
(1.23 MiB) Downloaded 131 times
enigma2-plugin-softcams-oscam-icam-openatv_r11781_all.ipk.zip
(1.85 MiB) Downloaded 134 times
#17
Oscam für DM9XXX / VU+ 4k mit u. ohne ipv6 und emu Support ibdvbcsa integriert binaries only
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-mixed-upx
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed-upx
oscam-git11782-801@1346db01-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx
oscam-git11782-801@1346db01-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx
oscam-git11782-801@1346db01-mipsel-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed-upx
oscam-git11782-801@1346db01-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed-upx
oscam-git11782-801@1346db01-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed-upx
oscam-git11782-801@1346db01-vuplus4k_armv7a-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx
thx uf2k
oscam-git11782-801@1346db01-vuplus4k_armv7a-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-up...zip
(624.49 KiB) Downloaded 59 times
oscam-git11782-801@1346db01-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed.zip
(714.48 KiB) Downloaded 89 times
oscam-git11782-801@1346db01-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(712.58 KiB) Downloaded 61 times
oscam-git11782-801@1346db01-mipsel-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(684.91 KiB) Downloaded 57 times
oscam-git11782-801@1346db01-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon...zip
(682.64 KiB) Downloaded 141 times
oscam-git11782-801@1346db01-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-...zip
(681.38 KiB) Downloaded 85 times
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed.zip
(630.69 KiB) Downloaded 54 times
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx...zip
(630.66 KiB) Downloaded 64 times
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(629.25 KiB) Downloaded 71 times
oscam-git11782-801@1346db01-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-mixed.zip
(629.48 KiB) Downloaded 68 times
#18
Oscam für DM9XXX / VU+ 4k mit u. arm / mips / aach64 Support u. ibdvbcsa u. emu integriert
IPK r11782 nur für OpenATV Image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv_r11782_all.ipk
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11782_all.ipk
IPK r11782 nur für VTI Image: arm / mips
enigma2-plugin-softcams-oscam-icam-vti_r11782_all.ipk
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11782_all.ipk
thx uf2k
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11782_all.ipk.zip
(1.33 MiB) Downloaded 56 times
enigma2-plugin-softcams-oscam-icam-vti_r11782_all.ipk.zip
(1.32 MiB) Downloaded 77 times
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11782_all.ipk.zip
(2 MiB) Downloaded 61 times
enigma2-plugin-softcams-oscam-icam-openatv_r11782_all.ipk.zip
(2 MiB) Downloaded 51 times
#19
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-mixed-upx
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed-upx
oscam-git11784-801@3fe0194c-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx
oscam-git11784-801@3fe0194c-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx
oscam-git11784-801@3fe0194c-mipsel-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed-upx
oscam-git11784-801@3fe0194c-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed-upx
oscam-git11784-801@3fe0194c-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed-upx
oscam-git11784-801@3fe0194c-vuplus4k_armv7a-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx
thx uf2k
oscam-git11784-801@3fe0194c-vuplus4k_armv7a-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-up...zip
(624.61 KiB) Downloaded 57 times
oscam-git11784-801@3fe0194c-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed.zip
(714.63 KiB) Downloaded 60 times
oscam-git11784-801@3fe0194c-mipsoe20-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(712.42 KiB) Downloaded 57 times
oscam-git11784-801@3fe0194c-mipsel-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(685.05 KiB) Downloaded 57 times
oscam-git11784-801@3fe0194c-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon...zip
(682.37 KiB) Downloaded 49 times
oscam-git11784-801@3fe0194c-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-...zip
(681.93 KiB) Downloaded 74 times
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-upx-mixed.zip
(633 KiB) Downloaded 72 times
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-ipv6-icam-neon-upx...zip
(631.16 KiB) Downloaded 71 times
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-upx-mixed.zip
(631.88 KiB) Downloaded 76 times
oscam-git11784-801@3fe0194c-arm_dream-webif-dvbapi-ssl-libusb-libdvbcsa-emu-icam-neon-upx-mixed.zip
(629.85 KiB) Downloaded 50 times
Re: OScam/EMU arm32 (DM900/920/all-VU4K, armv7)
#20
IPK nur für OpenATV Image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11784_all.ipk
IPK nur für VTI Image: arm / mips
enigma2-plugin-softcams-oscam-icam-vti_r11784_all.ipk
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11784_all.ipk
thx uf2k
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11784_all.zip
(1.33 MiB) Downloaded 77 times
enigma2-plugin-softcams-oscam-icam-vti_r11784_all.zip
(1.32 MiB) Downloaded 76 times
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11784_all.zip
(2 MiB) Downloaded 55 times
